crewcab dually with allison jet engine
Started by wayne4000, August 19, 2008, 11:27:09 PM
wayne4000
is there a class for my truck ,any tips on build ,what kind of tires  should i use ,can i use stock glass ,what are the rules on roll cage , any idea how fast truck may be :-D
Wayne4000
Dave Cox
Hi Wayne. unfortunately SCTA does not allow jetcars on the lakes or Bonneville. your bet bet is exhibition at NHRA, monster truck shows etc. I had a J34 powered car for a while, great fun!
desotoman
Quote from: wayne4000 on August 19, 2008, 11:27:09 PM
Sorry Wayne but no class for your truck. To be able to run at SCTA your motor must drive the wheels.
17dracing
 Sure does look like a big build !!!! What motor is that ? Looks alot bigger than the ones used in all the show off cars that run in NHRA !!! I know you can't run stock glass in NHRA or IHRA  sanctioning bodies ! Look into some info , on Art Arfons old toys !!!! He was the man at the aviation motors !!!!
McRat
Heck, since it can run on #1 or #2 diesel, run it at DHRA or NADM diesel drag events.  www.dhraonline.com or www.runNADM.com
The way things are going, they should let you run it street class.  :-D
#5
  Faster than the jet the engine came out of.
A few things missing on info. and pictures, my leg is being stretched. :?
McRat
I don't think it's a photoshop.  I think it's the product of a very sick mind.
I like it!   :-D
Racerboy
The Pick A Part jet Truck runs about 168 MPH and has the same engine that you have. I would check with Bob Vance at Pick a Part with questions. I would think NHRA and air shows is where you will find your place to run. That is where we run our jet funny car
Long Live the Comp Coupe's
I'd lose the high mount brake light - anything following that close will have bigger worries than if you're coming to a stop.
Constant Kinetics
If Allison makes a turboshaft version of that engine and you hook it up to your transmission or rear end, you could run it in the omega class, but check the safety rules. My build is based around using 2 much smaller turbine engines with the thrust of both collected and merged into a "Y" pipe hooked up to a tubineshaft PTO that i will probably order from Allison. Good luck, i'd like a picture with that truck if you can brring it out and run it.
Wierd is good
desperate
What a lovely engine. Gotta be pretty early as it stinks of Frank Whittle. Many years ago I bought a DeHavilland Ghost engine, as fitted to Venom and Vampire fighters, and the doomed Comet airliner. I think it was 1954? I paid £250 for it and thought it would be quite small. Wrong. The starter on the top was level with my eyes (I'm 5' 8") and the jetpipe was @3' diameter. I never did get around to firing it up, but I actually fell in love with that motor, until I bought a brand new, still in the box, Merlin.
You have good taste Sir!
Don't push me, I'm close to the edge.
oz
Hey Chris show them the pictures of it mounted in the Transit van.... Way coool!!
#12
 Maybe you could get a missfired bunker busting bomb [ the front part designed to bust through concrete with no explosives in it]
and mount it on the front of truck, then use a long steel cable for the parachute line.
 This will enable you to be winched out of the middle of floating mountain with little damage to truck and make adjustments for next run :-P
            JL222 :cheers:
P.S. don't foget the streamlined fuel trailer with blowoff hitch
