Gussets
Started by SFC Rashley, December 30, 2004, 01:45:00 AM
SFC Rashley
I have a 8 point drag race IHRA certified cage, but without gussets. Do I need them? The picture doesn't have them. Will I need that 5th bar too? I will run AA/GC
Thanks Gentlemen,
How do I add pic's?
Gary Perkinson
Third paragraph, section 3.B.2:
"Gussets are required at tube junctions of hoops and shoulder rail. Gussets shall be made from mild steel, .125" minimum thickness and four (4) inches per side, (preferably stitch welded on the outside of the tube junction) are required at all shoulder bar attachment points."
Gary
LTA     G/BGALT Record (1 mile)     143.313
LTA     G/BGALT Record (1.5 mile)  148.321
ECTA   G/BGALT Record (former)    153.009
Just because I have always thought that the SCTA specified gusset design that is really a pretty bad idea is it acceptable to make the gusset from say a piect of rectangular tubing the same size as the roll bar, say 1-1/2 by 2-21/2 with .065 wall and cut it to fit around the roll bar and then welded it as the gusset? To me this is a much better gusset design and it transmits the loads to the complete tube not just to the edge as the 1/8 plate would do which would probably just tear the edge of the tube away if you got on your lid.
Bob Drury
Okay, guys, one more time, If you have a question about the rule book, call the tech guys whose names and phone numgers are IN THE BOOK.
   My own opinion is the gussets are the MINIMUM allowed.  The bottom line is you need to have a triangulated brace at the roll bar intersections SHOWN AND MENTIONED IN THE RULE BOOK.   Bob
Bob Drury
jimmy six
Thanks Bob you are correct, Tech men first.
The reason for the gussets: a competitor got upside down in a lakester which had a cage welded on a shoulder bar (multiple times) It broke off and the man lost his life.  The gussets are to be placed on the inside or outside the joint and not centered. They are to be stitch welded...This is how it is shown in the book page 24. They are flat plates.
SFC: I do not know what the specs of a IHRA cage are. Thickness, diameter, material, etc. We do not hit walls and since the record is 260+ mph and safety folks may take a little time to chase you down in an emergency(not like the drags). Our specs were written by experienced people who have witnessed what didn't work. If all of your cage meets the specs of the SCTA book then adding the gussets to the inside of the necessary junctions with the proper plates should not be a problem.
Good Luck.
John Beckett
From an engineering standpoint a saddle gusset is far more effective at tube junctions than a flat plate gusset. Just as effective as the saddle gusset, and at times better suited due to tube angles, are knee bars.
#79 C/BGCC
SFC Rashley
Wow, thanks Gentlemen. The rule book is a MINIMUN standard, so therefore, like the engineer said, saddle gussets are stronger. THIS is the info I need, so thanks again. Please send me pictures of your gussets please....
Also, what are the primary no-go's on the track. I have over six months to prep the car and I want it done right the first time. The drag boys certify chassis where ever you request them to be. Will your tech guys come to me?
I would assume this is a saddle gusset.
I found them at:JR Motorsports
c ya, Sum
SFC Rashley
GREAT!!!!!!!!!!!!!!!!!!!!!!!
Thx
One note is that I would make sure those are thick enough to satisfy the rules.
c ya, Sum
One of the reasons SCTA/BNI does not recomend saddle gussets is the salt can get to places you wouldn't believe. This side welded gusset with the corner open allows for this area to be cleaned and easy to inspect.As was mentioned earlier this design was determined best by several chassis builders and a few engineers.
If your not sure, best you contact the inspectors prior to welding or making a decision that you might have to change later.All safety rules are well thought out before being put in the rule book.
John Bjorkman
Tony,
Before you add gussets to your IHRA certified cage make sure the tubing size and wall thickness neet the SCTA rules, We require thicker tubing then drag racing due to the longer response times for a crash and the track surfaces we run on. Cage tubing should be aminimum of 1.625 dia. with .12 wall
Good luck
Randy Williams
Tony, I'm using 1"X .083 tubing for my gussets. It might be best if you call Joe Timney at Delaware Chassis Works.He can answer all your questions.
jtimney@ecta-lsr.com
jimmy six
If you pre enter the Speed Week meet a copy of the back side of the inspection form will be included with your confirmation. I usually keep copies of the sheets at home to send out to those who ask. My address is in the rule book. Current year ones are available after the May SCTA El Mirage meet.. Good Luck J.D.
SFC Rashley
Thanks Gentlemen,
Need to do my homework...........
