turbo motor build
Started by Jonny Hotnuts, January 05, 2009, 05:59:49 PM
Saltfever,
Look on page 106 of the April 2009 Hot Rod they show a pic of a squirter made by Katech Performance. Might work for you.
Loss of oil pressure at high temp is usually caused by internal leakage in the oil pump. Not having any experience with a Busa I would guess that it has a gear or geroter style pump, when the oil thins it leaks from the high pressure side of the pump to the low (inlet) pressure side so not only does the oil pressure fall but the oil temperature is accelerated by the leakage. Most pressure control valve are nothing more than a ball with an adjustable spring and they seal pretty well even with thin oil unless there is dirt between the ball and the seat.
Oil coolers fix these problems. If you are running a water tank then some of the after market oil/water heat exchangers would probably be the trick setup.
saltfever
Got it. Thanks, Rex.  :-D
Nice idea . . . it looks like the oil supply comes up through the stud that is tapped into an oil galley. Hmmm, I wonder how much horsepower it costs with the piston pushing against the oil spray?
Quote from: saltfever on February 14, 2009, 03:07:50 AM
.... Hmmm, I wonder how much horsepower it costs with the piston pushing against the oil spray?
A lot less than the benefit  :-o
McRat
Absolutely oil squirters cost some power.  But I doubt it's too much.  It sprays with the piston going up, as well as going down.  So it's like a windage loss.  It's useful for sustained high output on super/turbocharged engines, because the amount of heat the piston must absorb can be over twice the amount of heat a NA engine will ever see.   If you allow the piston to get too warm, cracking becomes an issue, and if you spray nitrous, it can actually ignite the aluminum in the piston if you get greedy with the boost.
It's a necessary evil for some applications.  Until they come out with useable ceramic pistons or other technology, it's the best band-aid available.
Beryllium pistons anyone?  :-D
Jonny Hotnuts
QuoteJH  i don't think there is a pressure relieve in the filter, but i'm curious now and will go cut one up to be sure.
I asked a buddy of mine about why he was using a very different oil filter setup on his busa and he is the one that explained to me that the busa does have a bypass and he cut one up and to see if there was any trash in the filter after blowing a motor and found that it had a bypass and the filter was spotless. He is using the high pressure high volume setup and found the suzuki filter bypassed at 100 psi.
Here is the filter he is currently running (BTW: this bike did 8.38 without boost, not too bad!) He now says that it is spotless in the pan when the motor is taken apart where before it was always a mess.
jonny_hotnuts@hotmail.com
*Andres Segovia
The old Ferrari 250 and 330 front- engine V12 cars had two oil filters mounted upside- down on the front of the engine. One was a conventional oil filter (PH2815); the other (PB50) was a filter for the bypassed oil. This way the oil passed through a filter under all conditions.
1212FBGS
a Suzuki oil pump will NOT build 100psi pressure and the coyning will blow on most crimp styled oil filters around 85 psi... your guy is FOS....
kent
Kent;
A PH2815 could be replaced with a commonly- available PH8 oil filter but the first time you started the engine it would rupture a PH8.... BANG and oil everywhere.  :oops:
1212FBGS
yep been there blown them up too... i've even blown oil coolers up..... at least his friend sent him in the right direction with the oberg..
kent
ol38y
Quote from: 1212FBGS on February 14, 2009, 01:04:36 PM
kent
Why doesn't that surprise me?  :mrgreen:
See ya in May Kent... :cheers:
Larry Cason
2010 BUB 1350 M-PG record
Jonny Hotnuts
Quotea Suzuki oil pump will NOT build 100psi pressure and the coyning will blow on most crimp styled oil filters around 85 psi... your guy is FOS....
kent
http://www.rcsperformanceonline.com/Billet_Oil_Pressure_Valve_p/billet%20oil%20pressure%20valve.htm
QuoteFor replacement of the OEM oil pressure valve. Designed to create higher oil pressure for your high performance engine. The OEM valve creates 71 psi at high rpm. The high quality Billet Oil Pressure Valve creates 125 psi at high rpm.Able to be used on the GSXR 750, 1000, and 1300. The billet oil pressure relief valve has been successfully tested in Drag Racing & Daily riding with outstanding results.  Built to help prevent bearing failure from low oil pressure at high rpm.  Great for high compression naturally aspirated motors & nitrous applications.  This should be used in conjunction with the high volume oil pump gear. The gear gives you the volume, this gives you the pressure. Both are recommended for the best results.
Please Note - You must tighten filter with a wrench and let the bike get to operating temperature before revving the engine or you will blow the gasket out of the oil filter.
The high pressure/high volume setup pressure is well documented, the busa pump can in fact make more that 100 psi oil pressure.
Again your perceived knowledge of everything and your assumption of this has once again proven that you are the one thats FOS.
Seriously get over yourself.
:-D
*Andres Segovia
Jonny Hotnuts
Got a few more parts today.....got most of the expensive stuff out of the way now its just nickel and dime city.
I will be doing an oil mod on the case and need to get the bearings here before I start assembly. Once the bottom end gets back together I will be getting some head work done (porting, 1mm larger exhaust and SS valves, HD springs....ect). Will sure be nice to get things back together!
*Andres Segovia
Jonny Hotnuts
-ALSO-
Both the rods and pistons have "Nascar" stuff on the boxes....hope that doesnt make my car want to pull hard to the right!
*Andres Segovia
Right?????????
fredvance
What oil mods are you doing to the cases?
