Paging John Noonan!
Started by Rocky R, January 11, 2009, 04:26:21 PM
Rocky R
Sorry to do this but...my computer threw a rod and I had to replace it. Lost a lot of contact info. Working on articles and need to replenish my contact list. If John Noonan reads this, please PM me your email. (or anyone knowing it)
I'm sure there'll be more so sorry in advance!
Rocky Robinson  :cry:
www.rocky-robinson.com
www.rocky-robinson.blogspot.com
Roadsters.com
Rocky, this might not help you, but when move up to a newer computer, I take the hard drive out of the old one and toss the old CPU. Then I put the old hard drive into my $50 NexStar GX hard drive power supply, connect it to the new computer, power it up, and the icon for my old hard drive appears on the desktop of the new computer. Then I can click and drag whatever old files I need onto the new hard drive.
Here it is: http://www.amazon.com/Vantec-Nst-370Gx-Nexstar-External-Enclosure/dp/B000CDR8PU
Dave
http://www.roadsters.com/
Roadsters.com
Rocky R
Thanks for the computer 101. I'm still learning as I go. I did do a file transfer and got most of my documents and program files. For some reason had issues with email. For one, I was using Outlook Express. My new computer uses Windows Mail, which is a newer Vista product. They don't seem to be completely compatible.
I was thinking about beating my CPU into a round, cylindrical shape, packing it into one of the parachute cansiters in the Ack Attack, and ejecting it at speed! (wouldn't really do it because ejecting parts from a motorcycle streamliner has a high failure rate and is hard on the salt! heehee)
Rocky
Roadsters.com
Glad if that helped you a bit. I just save the old hard drive, and then put the drive-less CPU in the Recycling bin.
Dave
John Noonan
Rocky,
Yes you can use my images and I will get with you tomorrow..the email you sent went through.. :cheers:
Then there's the easy way to set up a new computer.  Have the old one be an Apple -- and the new one be an Apple.  Take the new one out of the box and power it up -- and you'll first get a step-by-step that has you plug in the (included) firewire -- and about ten seconds later, all of the stuff from the old one is in the new one.  Programs, address, files, folders, photos, and everything.
Of course it requires you to learn how to do things in the Apple way, Rocky -- but once you get the hang of everything having reverse-Whitworth threads -- it's very easy.  And about zero viruses, too.  I hear that recently there was one for Apple, but that's it -- ONE in the past few years.  And best of all -- no Vista!
