32 Roadster-who prefabs cages?
Started by slepe67, February 18, 2009, 06:13:07 PM
slepe67
Just like the title says, who builds a prefab cage for a 32 roadster?  I can do it, but for the price, my time is more precious than $300. (At least, that's what S&W's 10 point cage for a 32 coupe is).  Pretty much, I'm building a D/STR car, and will need the typical helmet cage, etc.
Any help is greatly appreciated. Thanks in advance.  JL
1932 FORD 5 WINDOW COUPE, ORIGNAL
302 SBF, 4 Speed Top Loader
MONTANA BORN & RAISED, STATIONED IN FL
maguromic
#1
WOW $300 is a good deal!  But be careful as some drag cages don't meet the thickness requirement.  A search on here will find some good threads.
Quote from: slepe67 on February 18, 2009, 06:13:07 PM
I didn't look for S&W's cage, but considering that the cage is in the air and our racing is all about aero I would want the cage designed around that in the car as well as for the safety aspect.  You can see the difference in speeds between the cars that take that into consideration and those that don't.  I can't see a generic cage being the optimal one for LSR.
Good luck,
promachine
Your cage should fit you in the car, aka custom build. If your on the left coast you can have it built at Vintage Hot Rod.
Dirty 2 driver-nitro junkie-H.P. peddler
interested bystander
#4
Pro Machine is right. Look at the two attached pictures - both record holders.
Although S&W makes fine products yrs truly is sure their '32 coupe rollbar is WAY too bulky for a SERIOUS effort.
5 mph in pit area (clothed)
Bville701
Quote from: interested bystander on February 18, 2009, 07:42:01 PM
Although S&W makes fine products yrs truly is sure their '32 coupe rollbar is WAY too bulky for a SERIUOS effort.
How did that yellow roadster do in the wind tunnel?
Ryan LeFevers
Not sure how good it did in the wind tunnel, but it broke the car in the lower picture's record by 8 MPH!
Very recent NASCAR motor vs California Hot Rodder Hilborns and Vertex mag of ten years or so back.
Bville701
Wow! That's quite substantial!!!  Thanks for the pics.    :cheers:
Ryan LeFevers
maguromic
#8
Looking at the wind tunnel picture of the 531 roadster its interesting some of the changes they made.  The hood scoop is smaller and the windshield kick up is smaller (this is inline with the modern open wheel cars) to help lift the air over the roll bar.  Take a look at the front torsion bar suspension. When I was talking to them on salt it was  mentioned that they had an air conditioning condenser (a little over 1" think) for the front radiator (I think it had the fins stacked tighter to help block the air) to gain room to move the axle forward as possible.  A  lot of little gains can help.
Bville701
Ryan LeFevers
Dynoroom
Tony, what's the big rectangular hole in the rear deck lid??
maguromic
#11
On my '32 I played around a lot with the windshield area and found gains on the CFD runs I did.  This is one of the  many models I ran.  It used a small 1/2"  kick up on top of the windshield riser. I also played with the shape and angle of the riser.
maguromic
Quote from: Dynoroom on February 18, 2009, 08:34:12 PM
I cant remember what they told me, I think was some sort of tank fill.  But I am not sure. :?
Tony
Bville701
That's really cool Tony. What program is that?
Ryan LeFevers
#14
The big rectangular hole was an ILLEGAL duct opening. They went to USFRA's WOS and snuck that run in .
They later came back and legitimately got the record in  '08.
Thanx for picture ,never saw it, just had reports of it.
DON'T TRY THIS ON THE SALT FLATS OR THE LAKE BED! NOT IN STREET ROADSTER, anyway.
