Spings or No springs
Started by 41ratrodguy, February 23, 2009, 03:48:35 AM
41ratrodguy
Not sure if this has been covered.....can't find it so I am posting. I am soon to start a build on a P38 belly tank lakester. I will be running traditional solid axle up front and a ford 9in in back. I have noticed that most people seem to have no suspension on there cars like this (lakesters and streamliners) at all. I would think that even minimal suspension would be good because the salt isn't perfectly smooth. But, I'm coming from a NHRA back ground and have never made an official run at B'ville. I would appreciate any advice in this subject as I don't want to be the rookie that spins out on there first run. However amusing it may be to the veterans  :-D
Bob Beatty
41ratrodguy,
Having run cars both with and without suspension, I would definitely build the car with suspension.  You don't need much travel but I think you will be happier with some.
Bob Beatty
There is no such thing as too much horsepower
338.954 MPH
B/BFL
Quote from: Bob Beatty on February 23, 2009, 05:56:38 AM
41ratrodguy,
Ditto, perfect salt and a car designed with no suspension (Costello's cars) will probably be faster since you can design less frontal area with no suspension, but then again if the salt is a little rough you might find yourself on the trailer that year after spending money to enter and gearing up for a whole year to run.  I want some just so I can run those times and feel the car will hook up better with some in the back.
c ya,
Why would you want to run a 9"- :?--this is not a drag strip with slicks.
41ratrodguy
Well, my idea was to build a car with suspension that has no more than 2 inches of travel. That is one up and one down. Also, with the capability of easily solid mounted if I want. I would use coil-overs in the rear but, on the front would be a traditional spring as it seems to be the only way to mount a solid axle and retain the ability to "lock" it out. The only problem as I see now it how to go about limiting the travel of a traditional solid axle spring. I could use cables to limit the travel as I have used on my drag cars, but the sudden stop in the travel could do more harm than good. Because in drag racing the cables are used to keep the front wheels from folding under the car when in a wheel stand. Is there anyone who has built a belly tanker using the traditional front suspension that could help shed some light on the subject.
        Thank You,
          Phil "the salt flat cherry"
41ratrodguy
Quote from: SPARKY on February 23, 2009, 07:45:31 AM
Because I come from an extensive drag race back ground and have several of these in my garage. Plus I have thrown over 1000hp to these rear ends. So durability and ease of access would be my main two reasons for using this type of rear end. I'm going at this alone. I have no sponsorships or friends willing to make and investment (at least a financial one) so I need to stick with what I know best.
Quote from: 41ratrodguy on February 23, 2009, 07:48:03 AM......... That is one up and one down. ....................
I re-thought mine and I'm going to have about no up (up as in the car raising on the suspension).  If the car starts to lift I want it to have to lift the whole car weight right off the bat and not get momentum in the up movement before reaching the end of rebound.  That is my thought and I not sure what others are doing on this, but would like to know.
c ya,
RichFox
If you can you might contact Bob Lindstrom who runs the "Stay In School" roadster. That car was well known for spinning. In '08 Bob removed his suspension as recommended by Jack Costella and ran a flawless speedweek for a new D/BGR record.
jl222
Good question. Use all your drag racing knowledge about hooking up. Solid suspension cars spin their tyres and they add a bunch of weight to compensate for it or a big wing helps.
Not finished company showed up.
  jl222 :-D
Jerry O
41 ratrodguy
I am building a streamliner for this year and have suspension on it. My car has about the same frontal area as the Costellos cars, small front nose, so it can be done. Will it work? don't know but will find out soon. I designed my car with suspension mainly because I will be running at the Maxton track and feel I will need it there. I am new to land speed racing so I this may not to be the way to go. I'll let you know how it turns out.
Jerry
41 ratrodguy,
There really isn't much wrong with using a 9" at Bonneville because they get pretty efficient as the ratio gets higher, i.e. like 2.43 or less that you need for Bonneville. They are much less efficient when going with the drag race ratios. When the pinion starts getting down to 9 or 11 there is lots of sliding motion between the pinion and ring gear teeth so you get more friction. If you've got 9 inchers and you are confident in your experience with them I don't see a good reason to change. I'll bet if you went around and counted at Bonneville there are more 9 inch Fords than anything else.
And I will bet that most of them are run for the same reason---there and easy---
Will you have so much power that you can throw 4+% away?
desotoman
Sparky,
What type of rear end do you run in your lakester?
desotoman
Sparky,
Sorry, I did not mean sprung or unsprung. I wanted to know the make of the rear end, ford, chevy, etc.
