Safety Wire Question
Started by hombre, March 12, 2009, 11:48:59 AM
hombre
I'm familiar with drilling bolts and general safety wire technique, but how does one safety wire a spin-on oil filter? It has no tabs or flanges that could be drilled.  :?
fredvance
Alsays wondered about that myself.
McRat
If I were to do that, I'd make a retaining clip that holds the bottom of the filter, then safety wire the retaining clip.
dick elliott
Rap a large hose clamp around the filter, and wire to it. Been doing it for years on road racers and not one has come loose. (YET)
Its better to be a has been, than a never was.
we drilled a .040 hole in the crimp and wired to that... worked OK... no problem
hombre
Thanks for all the fast replies, guys! If the crimp looks too thin to drill and hold, I'll use the hose clamp method.
I think it's the K & N brand -- that has a hex fastener head on the top of the filter, and I think I remember that said hex is drilled for a safety wire.  If not K & N -- someone else, but one of the bigger names in the filter world.
Dick's hose clamp method is by far the most common method to safety wire the oil filter.
Tzoom
K&N makes them.  I didn't check to see if they are drilled for safety wire but I think it would be easy enough to drill.  http://www.knfilters.com/oilfilter.htm
Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games --- Ernest Hemingway
55chevr
Every motorcycle sanctioning authority I know of accepts a hose clamp aroung the filter that is then safety wired to the bike ... I have used this method in the past but it is hard to beat the K&N filters with the integral nut already drilled for wire.
dick elliott
Problem with the K&N, is the safety wire is 5" or so from any thing to tie it to on most engines
1212FBGS
hose clamps used here!
kent
Dean Los Angeles
Quotehose clamps used here!
kent
Enough about yourself, how do you hold the filter? :mrgreen:
1212FBGS
zip ties and duct tape...... with an occasional dry wall screw!
Kent
hombre
Turns out K&N does make one that fits with the pre-drilled top knot. Thanks again for the info!
