Question about gas tank protector in unfaired class
Started by Rchop, March 13, 2009, 03:44:14 PM
Rchop
I have copied this post from my build diary regarding unfaired rules...
I have a question about the "tank protector" I want to install. I have 2 ideas...one is like a simple skid plate that has been recommended and the other is curved horizontally in front of the tank with a bottom plate also. Both are designed to deflect anytyhing picked up by the front tire. The question is: will either of these designs disqualify me from running in the "unfaired" class, such as A/PBG
Here are pics of each mocked up with cardboard...
www.frsengineering.com
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
1212FBGS
I have no idea what they would look at, but if I was looking I would say the rounded one does give you and aero advantage over the front of the tank unfaired.  So to have a squared off tank and then an aero shaped shield would in my mind constitute aerodynamics.
Now if the front of the tank was rounded to gain the necessary volume and the shield was in the same shape you might have a case, but probably a pretty thin one.
Nice work though and remember I won't be in impound inspecting anything, so the above holds no water,
Rchop
Quote from: 1212FBGS on March 13, 2009, 05:18:24 PM
are you looking for an ecta or SCTA answer?
kent
Mostly ECTA Kent. I doubt I would run it at Bonneville without that fairing you made for me.
Thanks for the response Sum.
#765 A/G 650cc
Rchop
Todd Dross called last night and gave me some tips on the tank protector plate. It looks like I'm going to build something that follows the shape of the tank so there is no aero advantage. I have some aluminum plate that I will use, so if it does touch something hard, there will be no sparks.
Thanks Todd :cheers:
#765 A/G 650cc
55chevr
Sparks ... Maxton problem ... you wont have to worry about that at Bonneville ... Joe
Rchop
Quote from: 55chevr on March 15, 2009, 10:14:20 AM
The gas tank is mounted low to present a narrow profile for running in the unfaired class at Maxton, Joe. I will have the Charlie Toy fairings on it when I run at Bonneville. There are a lot more places to put the tank when I have the fairing on, if the low tank conflicts with the fairing.
#765 A/G 650cc
