Engine dimensions:
Started by Rex Schimmer, March 31, 2009, 07:37:17 AM
Well I am on the third iteration for my lakester, talking to Blue to much!, but I am now in need of some engine basic dimensions. I am planning to run a Suzuki GSX R1000 engine for the "I" class. Anybody have a web site that might have some overall dimensions and specifically right now I need to know the location of the drive sprocket to the center line of the motor.
I know I should just cough up some money and buy an engine but I am still at least a year away from actually doing something with steel so I figure I have better things to do with the money.
If anyone can help I would sure appreciate it.
Rex, do you have a sketch of the info you need?  If you pop one on here, I'll try to get a motor measured.  Of course, you may want a generation 2 1000 by the time you get around to cutting pipe, don't have any 06 of later motors.  :|
Jonny Hotnuts
I could easily see a setup that would allow the drive sprocket to be moved latterly up to +/- 3" on the drive shaft to accommodate MC motors from K to G. Plus a method for being able to move the drive sprocket will allow for alignment adjustments if the motor was a bit "left of center" (or right!).
This is how I did my setup.....
Considering running a blown 1K for WOS....that is.....if someone is showing up in SW with a bird of another feather.
:evil:
If you still need a precise (within .25) measurement let me know and I can get ya one this weekend.
jonny_hotnuts@hotmail.com
*Andres Segovia
John HN,
I was looking on E bay and there are quite a few 2008 for sale so if you get a chance I would need the total width, got to make sure the tank I build is wide enough! and also the distance from the center line of the motor to the center line of the drive sprocket.
Any thing will help!!
Thanks in advance.
I sure would not get one from a CA emmision leagal sate---in the past a huge difference--  not current now big differece in the way on peformed CO vs NY
bvillercr
Rex, how you doing on your lakerster?  Got any pictures yet?  :cheers:
Bvillerer,
Still making drawings and trying designing some tooling for it but once I get something that looks like it is finalized I will start a build thread. Probably at least a year away.
