charlie101
#300
Regarding you didn't misplace your tin foil helmet, it has to be laddersteps on the next project intercontinal spaceship delivery rocket, Denmark-Bonneville! :mrgreen:
octane
#301
Quote from: Dr Goggles on June 05, 2010, 08:06:08 AM
you're building a shredder, in case the missus finds your receipts?
LOL !!!
No missus at the moment.
Been there , done that.
I've turned into a sorry, lonely, old fart
with a severe allergy caused by the sheer notion that some other person
should have any saying whatsoever on what I do, how I do it, how much time I spend on it, and how much money I spend on it
Quote from: charlie101 on June 05, 2010, 05:25:10 PM
LOL !
Yeah: I'm working on a old-fart propelled rocket to get me to Bonneville:
Quote from: bbarn on June 05, 2010, 07:20:45 AM
Rollers for an external wheel based starter?
Quote from: desotoman on June 05, 2010, 10:44:06 AM
Pieces for the remote starter.
Bbarn and Tom, you're both right and I'm a generous guy
so both of you; please PM me, stating your size, color preference and a mail address
and I'll send them right away ( may not have the right size, but we'll sort that )
More on the starter later.
octane
#302
Working yesterday but took a brake to receive the parts made by my friend Jakob
New spacers , "bearing-adaptors" etc. for the rear wheel.
Old axle in the background , new considerably stronger one up front.
Wouldn't really know what kind of steel to use for such an application,
but my friend Jonny came to my rescue as he donated an axle off
some rather obese big heavy Harley Davidson
(I'm not a HD-guy so I forgot which...but it's BIG ).
That has got to be strong enough for my 340 pound bike.
We shaved it a little on the lathe to make it fit here.
Just need to make a thread for the nut on the axle.
BTW , quite irrelevant for this thread,
but hell, we all like interesting cars...don't we;
he delivered the parts in his brilliant old Austin Healey
Love it !
Nicely rebuild, but not "chrome'ly" overdone.
The lower 5 inches of the car was rusted away when he got it
and he painstakenly rebuild it without buying any new body parts.
Yeah: took him a couple of years.
Gotta go back to work ( real work...make money-work... now.
oz
Cool aerodynamics it may catch on!!
Desperate would wear it thats for sure.
charlie101
#304
I see! That belgian Tintin version 2:1. This was you and your friends testing edition 1:2 here? I got a pic. of version 1:0, but you wouldn't like to share that! However I show a picture of another test crew. Now git back in order!
oz
#305
Thats the purple helmets display team in the top picture if I am not mistaken.
may need more back pressure on the silencer!!
I aint seen that lot in years real funny displays all done on old Honda C50s C70s C90s Cool
http://www.sheepskullenduroriders.com/
mad dudes
TTFN
octane
#306
Sorry: double-post.
octane
#307
I'm still working like a mad-man ( real make-money-work ) weekends and all,
so haven't been able to do much on the bike.
A few later night hours is all.
But here's a short update to let you know that I haven't sunken into the ground.
Took the carb apart as it dawned to me that I probably forgot to drain
it after a start-up attempt looooooong ago.
Methanol is supposed to be quite aggressive so I was a bit worried:
...bad news: yep, I forgot to do it
...good news: no damage apart from a bit of corrosion in the bottom of the float bowl
Weird: when putting it back together the rubber-seal between the float-chamber and the bottom-piece
was too small...must be the methanol that made it scrink ???
The trick is to immense it in WD-40.
Hence the yellow container with the seal emmenced.
Yep: WD-40 will make it swell up.
I know from a test I did once when a discussion came up
about using WD-40 to loosen up a brake-piston if stuck in the caliber.
NOT a good idea as the test shows:
The WD-40 will make it a LOT harder to get the stuck piston loose:
Honda GL1000 front brake seal :
...after a few hours in WD-40:
...and after a couple of days:
Got the carb together all right.
Made an "inner fender" / splash guard.
Should have a double-curvature at the rear.
Whacked it in the blindingly naive hope that I could actually do that
BAM...BAM....BAM...BAM.....I don't need no stinking english-wheel...WHACK....WHACK....yes I do!!!!
Whack-job.
Maybe I should invest in some proper tools instead of delude myself
that it can be done with a plastic-tip hammer and a tiny anvil.
Never mind for now. It'll work:
...will go in here:
Got the parts ready for the roller-starter:
...One piece of scrap aluminum
...Two pieces of POM Delrin
bought cheaply from the local plastic whole sale dealers cut-off-pieces heap.
It's an amazing material.
The rollers will be shaved 'smooth' at each end,
and stuck directly into corrosponding holes in the Delrin , which can easily
act as 'bearings' for the rollers on each side.
...One Mitsubishi starter from the auto junk yard
Took the starter to pieces to remove the 'arm' from the solenoid to the cog-wheel
..as the starter will be connected directly:   cog-wheel--axle-->roller,
and as the bike starts, the cog-wheel will run for a short while freely ( not dragging the starter-motor)
by means of the over-running clutch ( blue arrow ) on which the cogwheel is attached.
More on all that later.
Octane, the "Shaping Aluminum with Hand Tools" DVD at www.covell.biz will show you how to beat that fender.  One thing I learned is to pound the fender out of an oversize piece and to trim it to its final size after the shape is OK.  Have fun.
charlie101
It will be interesting to follow your build of the roller starter. I'm exactly where you are at the pictures in my build, aquired a pile of almost all parts but is having problem to figure how to connect the starter clutch to a chain sprocket in a reliable way.  It seems easier to use a bike starter motors as there is several that already is using chain drives but I'm afraid the starters are expensive and too weak, and car starters are so much easier and cheaper to get. It would be equally interesting to see what starters you other followers have cobbled up.
ironwigwam
Lars,
   Why not drive the starter on the engine drive shaft as I do on the streamliner? It just takes a nut welded to a plate and bolted to your belt pulley? The sprag on the starter on the transmission is an expensive and weak link on the electric starter chiefs. Moen may have one down the street from you?
    Rocky
grumm441
The new workshop I am working in just purchased a thing called an easystarter
It looks like your usual roller race bike starter, but is powered by a 2400 watt angle grinder
Plugs into the power point
Used it twice yesterday, once on a CRF250 and next on 750 Bonneville
Worked a treat
When we were at Lake Gairdiner this year, John Trease from Harley Motorcycle Engineering in Melbourne had something similar, but powered by two 2400 watt angle grinders. Something to do with the hi comp Vincent Comet that was with him on the lake.
He had a honda generator in his pickup. Plugin, press button and woo hoo
octane
#312
Quote from: wobblywalrus on June 15, 2010, 10:02:21 PM
I will ! Thank you!
Quote from: charlie101 on June 16, 2010, 10:11:20 PM
Mine won't use a chain sprocket, but please see below where I post
pictures of those I found in my hunt for starter-ideas ( that I never folloewed..ha ha)
Quote from: ironwigwam on June 17, 2010, 04:43:13 AM
Lars,
Mostly because that would require some sort of transmission/reduction-gear between the starter and the drive,
to get enough torque / lower RPM from the cheapo car-starter.
Too complicated for a simple guy like me.
Quote from: grumm441 on June 17, 2010, 11:01:27 PM
Worked a treat
Something like this ?:
QuoteWhen we were at Lake Gairdiner this year, John Trease from Harley Motorcycle Engineering in Melbourne had something similar, but powered by two 2400 watt angle grinders. Something to do with the hi comp Vincent Comet that was with him on the lake.
Yep that would work,
but I would prefer to have a 12 V running on a battery.
Here's a few other variations. Some are apparently home-made,
others are some you can buy. The really nice ones are terribly expensive...up to 3.000$US.
SlyOneJr
Just for an idea, a good friend of mine has a H2 powered kart, and he made a rig that holds the chassis off of the ground a couple of inches, and uses and old horizontal shaft Honda go kart motor to spin another kart wheel mounted in a bearing to spin backwards against the tire on the kart, using belt drive and a tensioner assembly off of the bottom of the deck of a lawnmower, just pull the handle when the Honda motor running, the wheel on the starter starts turning, wait until the wheels on the kart get going, and drop the clutch in 2nd gear. Fires up the motor with no problems. I will try to get a few pictures of his "Kart Starter" the next time that I am over there and post them on here if anyone is interested.
Jeff
New Guy building a L/Gas Lakester
Ninja 250 powered Lakester for ECTA meets
saltwheels262
i use a dodge starter motor. powered
by 2 -12 volt batts.(24 volt)
if you go that route, put two handles on it.
maybe my pm didn't go through.
let me know if anything besides $ is needed for bub.
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
