Show & Tell
Started by Calkins, April 10, 2009, 08:32:39 PM
Calkins
Ok.  I just may be lucky enough to hit Bonneville this year.  So, I want to know who I'm typing to.  I'd like to be able to put a face to a name so that I know who I'm B.S.ing at the track.
I'll start.
bvillercr
should we start calling you chunk. :cheers:
Bville701
heeyyyy yoouuu gguuyyysss!!!!        :-D
Ryan LeFevers
Calkins
How's this?
Tzoom
Do you have any dating issues?
Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games --- Ernest Hemingway
Calkins
Yes, I do.  Why do you ask?
Tzoom
You look a lot different in that picture
McRat
Perhaps it was helped with photoshop? :?
Calkins
I didn't think there was that much difference
Texans will tell ya you are holding your hand wrong... the horns point up  :roll:
maguromic
If you need a date, I am sure this lovely gal would go out with you. Looks like she can weld too. :-o
Hey -- that "girl" looks pretty much like one of the guys I saw at a combination fuel stop/beer store as we drove through Tennessee on our way to Maxton last time.  I didn't ask if he had a sister.
This probably as good a place for this post as anywhere.
Found this while I was researching some stuff... found it interesting...
Machinist's Workshop Magazine (March/April or
May/June, 2007) actually tested penetrants for break out torque on rusted nuts. They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.
*Penetrating oil ..... Average load*
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ............. 214 pounds
Liquid Wrench ..... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix....53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone. Note the "home brew" was better than any commercial product in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
John Noonan
Quote from: Freud on April 11, 2009, 01:07:11 PM
Dr.
Thanks for the great info!!
J
desotoman
Freud,
Just curious, did they say how long they let the solutions set on the parts before they did the test? I wonder how long the Acetone would stay suspended in the ATF before it evaporates.
Over the years I have taken about 50 Flathead Ford engines apart and the best I found for the job was the Kroil. And I found out about it by mistake while working at a Nuclear Power Plant. Wish I would have known about Acetone & ATF. Over the years I have never had much luck with Liquid Wrench, very surprised to see it rate so high.
