2 II Ratical ---- aka Too 2 Ratical Liner #211
Started by SPARKY, April 16, 2009, 04:19:49 PM
HotRodV8
Quote from: theazoldcrow on December 22, 2009, 07:21:21 AM
:-D  Ray,  read my by-line.  "The Earth is an intergalactic insane asylum."  That shows me where us lsr people stand!     Crow.
Crow -
In this case, allow me to take the liberty of adding a few words to your by-line:
The Earth is an intergalactic insane asylum with two dynamic dissimilar drive trains orbiting it, each orbit controlled by a independent gravitational foot pedal.   LOL   :-D
SPARKY -  Remember to enjoy each day of the build.   :cheers:
landsendlynda
Quote from: HotRodV8 on December 22, 2009, 09:05:07 AM
Crow -
Now that is the most accurate description for LSR I've heard in a long time!!
Lynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
floydjer
Sparky....You have way too much free space in that shop :cheers:J.B
I grew up in TX and am use to a lot of space to roam around---what can I say!!!!!!   :cheers:
#109
 This post will attempt to show what  we are trying to accomplish with this TRANS/tire "Miss Match"
As MM said earlier, I am trying to keep my 2 engines from falling in to their flat spot at the same time--caused by not having a 6 speed trans with something like 1.90 1.48 1.15 .90 .70 .56
someday someone will do the the new GM 6L90E similiar---hopefully most of the ratios have been done---just not in the same trans
2.14 Gear set both ends
Went to LA for the SCTA banquet.  Picked up my rebuilt original 509 motor from Mike La Fevers at Mitech and had a great lunch visit.  Went  by Taylor Made Wheels to visit with Taylor and Chuck about new wheels.  After talking to Tom in M&H' Tech assistance I have decided to order 5 on 5  18x6 wheels and run 30s on the front and 26s on the rear.  Hopefully we know the final configuration soon.  After  having Lee Kennedy review my cage drawings at the banquet. I now feel comfortable with starting the cage.
We will need to rough the cage to see if we can get in and out of this thing and keep it inside the design parameters of the outer skin.
Chaz
 I gotta see this one! Folks think OUR design is nuts, so if you are on the salt at the same time you'll draw all the attention and we can slip by. :-D
  I really like the ideas you're putting out there. I forsee a lot of dialing in time, but hey .... Its a journey!
We are hoping we learned enough with the first car we dont attract quite so much attention as we did with RATICAL  :-D
We have the 4x8 build table done and 2 , 1/2 plywood tires that we will be building the cockpit on.
Will be  off to buy several sticks of 2 x .120 dom for the upper and lower tubes.
This weekend at the Gear Grinders Banquet I had a great vist with lots of fellow GGs. Jim Miller was there and got to send lots of time asking about our new cage.  We feel confident enough with what he and Lee are looking for to start bending and tacking to see if we can get in and out.  If he told me once he told me 10 times---PUT EVERTING ON INCLUDING THE HANS !!!!!!!!!!!!
Boy oh boy!! Being an Aggie we bent the first tube --- then read the instruction manual! Tommorrow for lunch we will be having BOOKS, scalloped potatos, and ham. lol
#114
First tube will form the back of the drivers area, and the back tube of the helment cage.  The cross tube will form the seat back there will be another as soon as we are satisfied that this is what we want.  From the center of the frtaxe the frt will extend 96" the outside of the hoop is 25" wide the inside will be 21" the top of the cage will be 34" AGL. The lower tube is 36" outside this is what we are trying to package.
Sparky, just a couple of things.
First, I'm hoping that the tube running into the centre of the cross tube is just a temporary item. I never like something like that pointing straight at the driver's back. I'd rather see supports at both ends of the cross tube.
Second, before you start welding, clean the end of each tube where it's prepared to saddle the other tube. Also clean the area on the second tube where the first tube is being welded to. A wire brush mounted on a bench grinder works really well. If there's any oil on the tubing it's worth removing it with lacquer thinner or acetone.
The quality of the welds will be much better. It's worth the extra effort when your life depends on those welds.
hitz
#116
Whatever you clean the inside of the tubing with ,I would strongly recommend washing the inside with detergent and rinsing with water.Warming the tube afterward will dry it and if you rinse with a little soap left in the the rinse water it will help keep it from rusting right away. The fumes aren't so dangerous as petroleum products when you weld. If you drill holes near the end of the tubes you will have an easier time closing up the end of the weld. I use a #55 drill and close the tube up with small drive rivets. Some people oil the inside of the tubes with a special oil/varnish mixture if they don't expect to weld on it again. Have fun.
Harv
#117
Thanks guys!!!!!!!The seat back will have 2 tubes like the single diagonal one we have for spacing and trying the clearance for the helmet and such. we plan on completely having this thing tacked and take to El M to be inspected. THEN taking it completely apart, beveling, cleaning then welding. We have a least one gas vent hole drilled under each tube joint now.
PS.  The dom we are using is 6 years old and has some rust on it. We are spraying with WD 40 and buffing with a paint scratch pad---also we are using some lithium poly sulfate wheel brg grease trying to protect the follower dies---nasty---all because we can save $1.63 per linear ft.---so much for Scottish heritage
desotoman
Sparky,
I found some Gas Pedals for you.
