2 II Ratical ---- aka Too 2 Ratical Liner #211
Started by SPARKY, April 16, 2009, 04:19:49 PM
This is the Rats Nest befor the build starts. :-o
Now that looks like a shop -- although it's got lots more room by our standards.
Stan
#92
I have had some ask about more details on 2 pass "The Radiator in a Box" heat exchanger
The only thing that is not shown is the iternal dividers and the external fittings that control the external coolant that will be pumped through the box in the opposite direction of the eng coolant and the two pumps that let me empty the box so that when I warm up the eng only the eng coolant is being warmed.  I hope this helps
Bville701
Sparky, we have done something similar with our radiator. I'll see if I can find some pics and I will post them later. I think you have some very good ideas right here.    :cheers:
Ryan LeFevers
#95
Thanks,  I am sure it isn't original---but it sure lets me control the eng temp better!!!
Crosley
The gear ratio - engine plan is interesting.  Sparky and I have discussed gear ratios of various transmittins, he had  interesting thoughts on them as folks now know here.
it's gonna be fun with the new build  and testing
what was that one phrase muttered ?  " How did Sparky get that car  over 3?"  ( posted tongue in cheek)  :-D
Tony in AZ...
"If you find yourself in a ditch.... let up on the throttle"
Sparky,
I like your heat exchanger idea and have been planning to do the same for the small lakester I am designing right now. It sure beats building a big tank that has to be able to run at 15-20 psi. What are the dimensions of your double pass radiator?
Rex outside of tank to outside 19" W x 22" L      hose fitting sticks out 2.5" from tank end.  I had an extra charge for having  the hose fittings put into what would normally be the side of the tank.
doug odom
Rex, Check out the AFCO scirocco style double pass radiator. My outer box/tank is 14" x 23" x 5". You can get it in left or right side inlet/outlet.  About $220 from Summit. Works in the streamliner great.
Doug Odom in big ditch
Sparky and Doug,
I am planning to run Suzuki GSXR motors so my cooling requirements will not be even close to what you need running big engines. My thinking is that doing the cooling this way the actual "radiator", because it is doing water to water heat exchanging, probably doesn't need to be very large. I need to dig out some of my heat exchanger info and do some sizing.
doug odom
I did water to water because I didn't want any air getting into the car except what it takes to run the motor.
RayTheRat
Quote from: PorkPie on December 19, 2009, 01:26:44 AM
How can coach potatoes, which are watching soap opera's, call himself normal and us crazy - may be we are normal and the other never learned to live......  :roll:
Great observation, Pork.  All I know about "normal" is that it's a setting on my washing machine.  Other than that, I'm doing my best to enjoy my insanity and not suffer from it.  :)
I thought I was on the page with Sparky until the two dissimilar motor/tranny thing came up...not to mention a throttle for each foot.  It gives me a headache just thinking about it.  I dunno about you, Sparky, but after driving vehicles with manual transmissions, my ingrained thinking pattern tells me to push the left pedal to the floor to shift and especially if anything out of the ordinary happens...like a spin.  I hope you never get the chance to test this out. I can't even picture driving that way...but isn't that the way tracked vehicles work?
Triet's project 550 has a single throttle that is split down the middle so Les can control the engines by rocking his foot. It's really neat. Les designed and machined it as well as other driver controls and injectors. This car has to be seen to believe the construction and detail of a master builder Jim Hume.
I am not putting down Sparky's ideas as that's what LSR is all about to build something to go fast.
Everyone has different thoughts and what works for one may not for others.
theazoldcrow
 :-D  Ray,  read my by-line.  "The Earth is an intergalactic insane asylum."  That shows me where us lsr people stand!     Crow.
