Air Vent for A/GC
Started by 32hotrod, July 27, 2009, 05:49:16 PM
32hotrod
Help in a last minute rush get ready/ The rule book states that there must be an air vent for closed cars which can blow fumes away from the driver.
Whats the simple solution for a 99% finsihed car
WZ JUNK
#1
On the #974 we have two oval shaped holes cut in the lexan windshield that are approximately 1" X 5".   They are located near the top of the windshield near the corner on each side.  Hooley drilled a hole on each end and then cut a straight line top and bottom to connect the two holes and make the oval shape.  If you have a lexan windshield you might consider this option.  We got this idea from the BMR coupe when we were faced with this problem.  I might be able to find a photo of the holes if you need one.  If your windshield is glass, I am no help to you.
Crew chief #974 B/BGCC 1953 Studebaker Past Bonneville record holder.
mkilger
if the windshield is glass? dont it need to be shatter resistant plasic (lexan)?
NathanStewart
Quote from: mkilger on July 27, 2009, 09:26:14 PM
Most windshield glass is safety glass.  It usually has a couple layers of film that hold everything together in the event of a break.
For the OP: Anything will work for a forward facing vent.  Remove a side view mirror?  Build a little scoop that directs the air through the hole where the mirror used to reside.  A lot of times the stock cowl vents work fine.  Just make sure they don't open up into the engine bay.
El Mirage 200 MPH Club Member
RichFox
On my coups I made a small scoop and put it on the roof just above and forward of the driver. You could almost stuck your nose in there if you had to. I did this after Joe Locosta gave me a talking to about the need foe such a device. he probably knew.
LSR Mike
Mike M.
BNI/ECTA
Forgive Mike, folks -- he races a pickup truck and therefore can't be expected to be really sharp so early in the morning.
thundersalt
You can get scoops like these in differant sizes at you local marine shop.
916 REMR
32hotrod
Thanks to all see you in few days
NathanStewart
I like to see the looks on the roadster guys faces when I ask them to show me their forward facing air vents.  Man some guys can't take a joke.   :-D  I guess tech inspection is the time to be light hearted.   :-P
jimmy six
Another option is a rotatable vent used in private aircraft. If you have lexan/polycarbonite side windows they are easy to install. Most aircraft parts stores at airports have them or contact Aircraft Spruce. Good Luck..........
