First time on the dyno
Started by racer x, August 02, 2009, 09:01:35 PM
racer x
Hello all
I have bin tuning my bike with the seat of the pants method.Or the old plug chop method. Then a year of trial and error racing the mile at Maxton. Then drag racing the 1/4 mile . All with OK results. Now I have enough stuff to adjust that I need help .
I have an assortment of carb jets and filter or velocity stacks.
Plus three exhaust systems with five different levels of back pressure .
A custom made ignition system that I can adjust the timing along 30 points
I have adjustable cam sprockets
different gears for the back wheel and two different tire sizes.
And I can use a 1 pint fuel tank on the dyno to test different octane fuels.
I have the bike running better than ever but want to be sure it is set up as well as it can be. So I have scheduled a day at the dyno . Dose anyone have any general advice for going to the dyno . I will figure out the bike part . But just want to get the most from my time. Thanks
Try to tune for right after the shifts and what you think you can PULL in the last gear!!!!!!!!!!!111
hotrod
Lots of people break parts at the 2-3 mile point on the course, if they dyno can sustain a load, hold the engine under full load long enough to determine if you have a safe tune down track after some heat has built up. A tune that is safe in a 20 second dyno pull might melt your pistons at the 3.
Larry
racer x
I only have to run a mile but I get your point . I will leave the load on the bike for the time it takes to run the mile . maybe a couple seconds more for safety .
RidgeRunner
A lot of good information in "Dyno Testing and Tuning" by Harold Betes and Bill Hancock.   ISBN 978-1-932494-49-5.
I found it well worth the purchase, have and continue to learn a lot from it.
            Ed Purinton
Dakzila
I'm sure I don't have to say it but just in case.
Since you have all day only make one change at a time.  After the change I'd make two pulls. First a full run through the gears at wide open throttle in each gear and chop the throttle at max RPMs. Second run, on the same setup, would be a slow run up through the gears and a hard roll-on in top gear to max RPMs.
After the runs check the top gear peak HP and torque locations (rpm range) on of each run sheets. If there are big differences in the peak HP (more than 5 HP) between the runs you might want to start looking at the cam timing.
My two cents worth...cam timing, ignition timing are going to be where you can pickup or loose noticeable amounts of HP and torque.
Depending on the induction system (blow through or draw and Injection or carb) exhaust would be the last thing I'll deal with. As far as the rear wheel unless there's a substantial  weight difference or circumference difference I'd leave that till last on the list.
Let us know how the tuning turns out.
Buzz
My Hinckley Triumph Bonneville has a worn cam chain.  The cam trails several degrees behind where it should be.  Usually I wind the engine tight in each gear and I shift at high rpm.  I rode on the big white dyno a few weeks ago.  I rode real conservative so I would save the cam chain.  As little time as possible at full chat.  At the 2.5 mile mark I was halfway to max rpm in top gear and at half throttle.  Then I got down on the tank and wound it tight.  At the 3 mile mark I was at top speed.
The bike worked really well.  Better than ever.  Is this to be expected for a lagging cam?  Is a lagging cam a good thing for top end power?
1212FBGS
 an "all gear" dyno pass is only for impressing your buddies with bigger numbers...... "roll ons" are used by people who know how to tune....
kent
Dakzila
Kent,
The "all gear" method can be a tuning tool also. Lots of good information on that run sheet that can be very beneficial with proper interpertation.
The two run method "all gear" and roll-on can be used together to not only setup and tune the engine but also look at potential issues with the lower end, tranny and the drive train that  might not, yet, be obvious or evident to the naked eye.
If the bike is tested properly every spike and dip on the sheet will tell you something about the engine and drive train.
Buzz
The dyno really helps us and we are only using it for a small number of the things it can do.  It is time for me to order the dyno tuning book and sit by the fire for some winter reading.
Does anyone have experience with changing the cam timing on a modern Hinckley Bonneville?  Dyno time is expensive here, and I was going to try standard timing and either advanced or retarded.  If changing the timing in one direction obviously does not work I do not want to try it.  The actual method to change the cam timing puzzles me.  On the old Triumphs I would juggle around the timing gears and the locations of the keys on the gears.  How is this done on the new ones?
robfrey
Quote from: wobblywalrus on September 16, 2009, 06:03:13 PM
Ooooh yeah! Cylinder continues to fill even when the piston is starting up the bore. This has to do with the ram effect of the manifold.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Thanks Rob.  Here is my plan.  Does it make sense?
I will have the engine apart this winter.  I will check valve head to piston crown clearance with play dough with both cams timed as per the manual.  Then I will check the clearance with one or both of the cams lagging one tooth on the upper cam sprocket.  Assuming the valves do not hit the pistons, I will dyno with the cams set as per the manual.  Then with one or both cams lagging.  Is it best if the intake cam lags, or if both lag?  Top end power is the goal.
Dakzila
Wobbly,
I'm not familiar with the Hinckley engine.  Is it an overhead valve engine with the cams driven by chain and sprocket? It's kinda sounds like it when you talk about moving the sprocket back one tooth.  Anyway....depending on how the sprockets mount to the cams you might be able to buy a set of adjustable cam sprockets or modify your cam sprockets by slotting the mounting holes.
Good luck,
Buzz
