One -way sprags
Started by floydjer, August 17, 2009, 09:11:32 AM
floydjer
How about using a sprag in place of the clutch? Lift off the throttle/shift/back on the loud pedal. I`m thinking out-side the box(as usual). Jerry
RichFox
In the long ago I had a drag bantam with a 241 Dodge and a cast iron torqueflite. Injected. Before stall converts. So I drop shifted it on the start line. Replaced sprags a lot in that thing. Kind of got to the point that I never wanted to see a sprag again.
rebelce
It must have been thought of before, it's OK in the rule book. Trick is finding one.
Ervin
Better question would be,,,,,WHY?
   Ervin
floydjer
Quote from: Ervin on August 19, 2009, 05:44:08 AM
   Ervin
So that if( I mean WHEN) the engine locks-up at speed, The drive train would free wheel. :cheers:J.B.
sheribuchta
had one on a boat   with a prop    and big block olds      willie buchta
Make sure the sprag (over- running clutch) is a "full- phasing" type. Early on there were helicopter crashes caused by sprag clutch failures; a few individual rollers locked up before the others and this caused the sprag to sieze. By controlling the rollers so they all acted in unison, the problem was solved.
Dave Cox
Quote from: floydjer on August 19, 2009, 12:37:50 PM
   Ervin
AMEN!
There are at least two cases where front wheel drives with sprauges on the drive wheels had one side lock up and crash. One free wheeling and the other not makes for a nasty ride.
John Burk
On front wheel drive cars the sprag needs to be between the transmission and rear . Drag boats also need overrunning clutches so I ordered one with the Casale V-drive I'm using as an overdrive in my front drive streamliner . Casale calls theirs a Whirlaway . That's where Dan Thomason and Ed Tradup got theirs for Dannyboy . Much stronger than the sprags used in production automatic transmissions .
Look up the company Formsprag on the net. They make any size you want, high quality and good.
hotrod
Throttle lift compression braking, or blown seized engine, or transmission, on a front wheel drive car would get very interesting (ugly) very quick at speed without an over running clutch. Same reason many cars do not run front brakes.
Larry
jl222
Quote from: hotrod on August 20, 2009, 01:13:47 PM
Larry
   Rear brake lockup= oversteer  Front brake lockup = understeer in the direction headed
floydjer
O.K. ,I`ve re-thought this. How about a spring loaded face-dog between the trans. and rear differential? :?
Genuine GM
I have alot of experience with Sprags.  I am the Chief Inspector a company that works on helicopters.  Helicopter component overhaul is what I used to do for a living and they all have freewheeling units to allow them to auto-rotate if the engine lets go.
To run one, it needs to be between the transmission and the driveshaft or the driveshaft and the rearend.  You could probably get a sprag out of a used helicopter if you called a operator, or a service center and asked nicely.  They have relatively short retirement lives in the aircraft and are removed in great shape and tagged unserviceable.
The problem is the size needed.  A turbine engine puts out a steady state rpm and torque.   To govern the power of the aircraft you change the collective pitch of the blades.  The RPM stays constant.
A Bell 206 Long Ranger will have around 400 shp and a Bell 407 will have 500+.  Those will be the most common sprags to run across.  If you ask you could probably get the inner and outer shafts as these have very minute damage limits.  I could email the copies of the maintenance manual pages needed.
The best might be out of a Bell 412EP.  1200SHP out of a Pratt and Whitney PT6T-3DF Twin Pac.  The clutch is in the engine combining gearbox and doesn't have the same retirement life as the other aircraft.  It would be harder to come across.  You would probably need to contact Pratt and Whitney Canada or Standard Aero and see if their overhaul shops have any laying around they could release.
For a smaller unit, contact your local PD, News, or other operator and tell them what you want to do and why.  You will probably have to sign some release form as the FAA has gotten strict on used-unserviceable parts showing up later on installed on an aircraft.
C. J.
Don't let the troubles in your head, steal too much time, you'll soon be dead - so play. You Never Know – DMB
