Motorcycle engine to driveshaft?
Started by Dreamweaver, September 04, 2009, 09:43:01 AM
Dreamweaver
How is the connection made from a motorcycle engine to a driveshaft made? Ive searched the net and seen a coupler that appears to go on the trans output side but what allows for the movement of the rear end?
Some sort of slip joint?
sockjohn
The only one I have seen was a Lotus 7 replica, and was basically a pillow block to support the end and a sprocket adapter.
Might see if some of the kit makers show photos of the parts online.
I'm not sure I really understand your question though  :?
ramjet
You use a driveline adapter on the out put shaft of the motor, then a U-joint then a driveline, with a slip jt. then another U-jt. at the rear end. Check out Dwarf Car Racing, on the web.
wolcottjl
Quaife makes some pieces for motorcycle engines in cars including a gearbox with reverse.
Here is one retailer that shows some of the units.
http://www.autotech.com/quaife/Motorcycle/cycle.htm?main=cyclecars.htm
Joel Wolcott
Moving to 2 wheels in 2010
Dreamweaver
Thanks guys, yall got me pointed to the right places.
Dakzila
Dreamweaver,
If the engine is mounted sideways you can use an automotive U-joint. Any shop that build Legend Cars can help you out with the adapt that mounts the U-joint to the tranny output shaft.
Buzz
Moonshiner
you could use a motorcycle engine that is shaft drive ,i have seen some home made trikes built using a modified miata drive shaft and the miata rear end , cost effective and works nicely .
mike mendoza
Quote from: ramjet on September 04, 2009, 10:21:51 AM
that's how i did it with my Dwarf car.   How about on a Harley?
Constant Kinetics
Quote from: Moonshiner on October 30, 2009, 10:00:41 PM
There are some quick Yamaha maxims that are already set up to run shaft drive. The water cooled maxim x series had the genesis engine (dual overhead cam, 5 valves per cylinder, 10,000 RPM redline) makes over 100 hp stock and responds well to 4 into 1 exhaust, carb re-jetting, or turbocharging. There are also big 1100cc versions that are a solid platform to build with.
Wierd is good
Tonerjockey
This is the way I do it:
Guzzi V7 Sport
YMMV
Alex
750cc P-PP (73 Guzzi V7 Sport - Porco Rosso)
50cc SC  (Weed Whacker)
100cc SC  (Heat Lightning)
