Ignition system recommendation for Methanol?
Started by RZ350, September 15, 2009, 06:45:19 PM
RZ350
I'm just looking for ideas here, any input is appreciated....
Engine will be a Kawasaki motorcycle, 74mm x 58mm, turbocharged, low to mid 30's for maximum boost, fuel is Methanol...
Would a MSD box with good coils be adequate?
What about spark plug heat range, gap, etc?
Or any car guys running Methanol, tell me about your setup, I'm interested in any and all information.
238 MPH at Bonneville
55chevr
used MSD box on turbo Kawi running alcohol ... used VW distributor with an angle drive ... no problems igniting the mixture ... it was on a drag bike ... ran 160's in the quarter all day long ...
1212FBGS
 stay away from car stuff on a motorcycle unless its a harley..... that V dub and car stuff is really only good for 8000rpm maybe 10 if your lucky....stick to good bike componets
kent
Dakzila
Dyna Ignition, for sure.
Couple of questions.  Blow through or draw?  Injected or carb? Slipper or lockup clutch? Any type of timing controller?
Let me know and maybe I can get close the the right plug range.
Buzz
RZ350
Blow through carburetors,  lockup clutch, fixed timing, figure 3-5 miles WOT on either the long or short course... :-D
sabat
Dakzila
RZ350
Twin, Dean! :-D
500cc EX500 engine, I just bought a new crank, transmission, etc out of a wrecked bike with 80 miles on it, studs for the top and bottom end of the motor, converted to a ZX6 charging system so that I have enough current to run all of the electrical stuff,  636 Kaw swingarm, and a bunch of other stuff...
It's most likely going to get my old TZ250 based fairing from my RZ racing days, plus a few more aero parts.
It should have a relatively small frontal area, make pretty decent power, and maybe go fast, we'll see about that!! :wink:
RZ350
No, Joe A's got that 1000cc Kawasaki thing covered, I'm just building half of that size!! :-D :-D
RZ350
.... and the 500 is literally almost a 1000 cc motor cut in half, same pistons, rods, crank dimensions, same valve sizes, the parts all look pretty stout....
sabat
