4wd `liner drive shaft enclosure
Started by floydjer, October 06, 2009, 08:53:54 AM
floydjer
My streamliner project is mid-engine (behind cockpit,forward of rear axle)and 4 wheel drive .In the area where the front drive shaft passes along the outside of the cockpit, I`m planning on having the shaft and all couplers inside .250 wall d.o.m. tube w/ smaller dia. tube inside mounted with  1/4 in. bolts. My thinking is the smaller tube will act like the liner in a  T/F drag car clutch can and spin . Thoughts/ Comments?  J.B.
floydjer
173 views and not even a like/dis-like??? :?
RichFox
It sounds good to me. Lots of steel between the driver and the shaft has to be a good thing. I guess everybody else thinks the same. We only like to jump in with "You can't do that" comments.
jl222
  Yea that sounds good, you going to use a funny car type drive shaft? How do you disconnect and reconnect to ring and pinion assuming drive shaft is offset.
When you're on the right track you don't attract a lot of comment.
Mr411Fan
Somewhere I have some pictures from the FIA meet where Tom Burkland broke the front driveshaft U-joint, and thier shield protected the driver very well.  The shaft runs right next to the drivers leg.  I don't remember the construction particulars, but it was tested.  The inner liner sounds like a good idea.
Herb
floydjer
Thought for a moment I`d been "silenced".  The rear trans. mount is aluminum plate much like an engine mounting plate, with the left side extending outside of the frame rails. Alum. drive hubs connected by belts to off-set the power to the forward shaft and the same at the front to get back to the center line of the front dif. Splined shafts w/ couplers and no u-joints.  :cheers:J.B.
