V8 Quick Change
Started by 32hotrod, October 18, 2009, 03:13:28 PM
32hotrod
Had a great first time event not to improve the car.
Anyone have any experience running a Winters V8 quick change, The champ version does not have the right geat combo and the ultraliner is beyond our budget.
With 1 to 1 in hi gear we need 2:20 or so to keep the BB Ford under 6500
Thanks to all for your comments
doug odom
What final drive ratio are you trying to get?
Doug Odom in big ditch
Once you get it -- don't do what Rick Yacoucci did, or maybe do do what he did.  He installed the gears upside down, giving him a much taller ratio than he planned.  The car ran 280 or so.  In impound he discovered his mistake and swapped the gears -- and his backup run was a 250-something.
Makes you wonder, hey?
32hotrod
Hi  we ran this year a 2:73 gear the C-6 and need to get into the 2:20 range but with the 8.8 rear that's not possible.
Options we see are
5 speed but that's a bit of a budget crunch
GearVendors OD but the final drive ratio is off as the ring and pinion go from 2:73 to 3.08 nothing in between that I have found
racergeo
   If you get the Winters with 3:78 ring and pinion you can get down to 1.80 .
revolutionary
I use a winters QC in my car and have found a great selection of gears on ebay for about 25 bucks a set.  Get a chart from winters or stock car products to figure out what set number you need.  BTW, I really like the ease of the quickie but the rear end noise is more than I expected.
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
GM 7.5 has a 2.28 and a 2.14  GM 10/12 8 7/8 has a 2.28
jimmy six
Not sure on the Winters but a Halibrand V8 QC can be fitted with a 3.25 ring and pinion and you can get under 2.00 with it. A lot of cars with over 800 HP run them...............Good Luck
