Racing backwards?
Started by twinspin327, November 06, 2009, 09:51:50 PM
twinspin327
I'm new to land racing. I'm still selecting a class to compete in. I am reading the 2009 rule book. I see the SCTA rule book say in the 5.B Vintage class that "Bodies shall be mounted in a conventional manner..." However, it doesn't say that in the 5.C Classic class. Can I race the car in reverse, not reverse in the transmission, but race backwards? I am serious about this question. In addition, I haven't located any information in Section 4 Definitions explaining "forward movement?"
I think I have an idea for a good shot at a LSR record. I have always been told that I think and color outside of the lines. I'd need to confirm this info before I start one of my projects.
Nortonist 592
I think if you start at the lights and run to the start line it will be OK.
McRat
Great question.  Since next year HANS devices will be required, call HANS and ask about their Linda Blair collection.
#3
NO---I don't think so--that been tried before and hence the RULE
sounds like you are going for Freuds record.  I believe he has the fastest reverse record on the salt and the freeway.  The trick to that record is you have to be in reverse.
If you read the rules better, you  will see that classic is just older cars and the regular rules also apply.  :|
mkilger
#5
build a roadster you should go backwards at some point :roll:
pookie
Twinspin327..... Back in the 1940's  there was a guy who mounted his roadster body on backwards and ran El Mirage...  Recall is a little fuzzy, I was too busy laughing as I kicked the slats out of my cradle..  No, Just kidding about the cradle. But you know what I think he either had top speed or set a record.. Better submit that question to the racing organization you plan to race with..to check on the legality.. But as Kilgore said , WHEN you spin, hell , you will look OK to the course workers and can keep going,but don't forget the rear view mirror.. Mike R.
55chevr
According to common folklore, the VW Beetle is more aerodynamic in reverse ... CD is beter ...
Nortonist 592
Quote from: 55chevr on November 07, 2009, 01:15:38 PM
With the HP a beetle makes does it matter?
Dr Goggles
Quote from: pookie on November 07, 2009, 10:23:06 AM
Manuel Butkie turned the body on his '27T around after Dean Batchelor suggested it would probably have a better aero shape that way,Batchelor drove it to a 148mph record at an SCTA meet at Elmo. There is a pic of Butkie at a Rusetta meet on page 60 of Batchelor's book " Dry Lakes and Drag Strips-The Story of the American Hot Rod" . A great book.
here's more on Manuel....
http://books.google.com.au/books?id=aYB_fHyg-V8C&pg=PA25&lpg=PA25&dq=MAnuel+Butkie&source=bl&ots=A9_MVeirKx&sig=xVsaoU35VQq423PKQclwaHiPVos&hl=en&ei=Gu71Sqv0NYbUtgOalOC0CQ&sa=X&oi=book_result&ct=result&resnum=1&ved=0CAgQ6AEwAA#v=onepage&q=MAnuel%20Butkie&f=false
Dr G
jimmy six
Jonny Hotnuts
many cars have better aeros backwards (big in small out). I have learned that just because it doesnt say it in the book wont make it OK.
There is the unwritten rule of "spirit of the class" meaning that the vehicle should conform to the standards of what the class and vehicle is. Building a body backwards on a chassis IMO will not conform to the spirit of the class.
I am not a rules official but I would say if you build it....you will be wasting your time 'cause it wont be allowed.
Good luck with it.
~JH
jonny_hotnuts@hotmail.com
*Andres Segovia
McRat
Pass, Class, Mass, Password, Bass.
McRat
Admin should remove "azz" from the cussword list, as it is used in too many words.
Well, yes, maybe -- but I've got the system set to modify words in which the combination of letters appears.  Maybe I'll get around to changing that setting.
