Sidecar Records
Started by bulldog, November 17, 2009, 08:36:59 AM
bulldog
What are the current FIM and National  speed records for sidecars and sidecar streamliner .
Thanks
joea
..there are a few hundred classes which one do you want
to know of...
I think they range from 36 to 218 MPH depending on organization, size and configuration
:cheers: (sorry Stan, thought a smiley was appropriate)
bak189
You never did get a answer regarding your question "what is the FIM and National sidecar record"  sorry,
The FIM World Record for sidecars at the present time is 208+mph set in 2009 at the BUB, and held by
Fritz Egli from Switzerland...
I believe the AMA National Record for sidecars is held by Craig Anderson at close to 170mph (this was a streamliner outfit)...
Question authority.....always
bak189
PS. to the last post..........there are also several AMA National Records in various displacement and configuration classes................(look them up in the AMA rule book for LSR)..............................
fredvance
Bob, your SCTA # is on the expired list.
  Fred
