I think a new set of rings and it will be ok.
Started by willieworld, November 24, 2009, 07:45:11 PM
willieworld
The first five pics are looking down the bore of the cylinders after I pulled off the heads. The pistons are not there.Here are the pics.
Willie Buchta
willie-dpombatmir-buchta
willieworld
A couple of more pics.
willieworld
The next pics are the cylinders the head and the motor with the cylinders off.
Willie Buchta
willieworld
a picture of the motor and a picture of the biggest parts of whats left of the pistons and they were stuffed down the sides of the flywheels.
Willie says he can fix it. He doesn't think the cases got hurt.
Willie Buchta
It will be running in May and setting records.
McRat
"What's wrong?"
"Front jug is missing."
"Bad plug?"
"Dunno.  When I find it, I'll look at the plug ..."
Willie, looks like you had a half an inch of salt on the piston and waited too long to clean up.
or
go down 2 jet sizes on the N20 and up one on gas.... keep the same gas pressure but keep your bottle out of the sun....
report back on how that worked for ya  :roll:
willieworld
i hear you   it was t cold at el mirage --i couldnt get the bottle pressure up ---i was #21 in starting lineup----ill get them next year   willie buchta
Damm you Stainless -- I was reading along and ready for a salt reply and you trumped me!
Stan
Better hone those jugs before you put in the new rings. A large pry bar and a vise should look after the rods. :evil: :evil: :-D
Willie, you didn't get a virgin.
Those look like most of the parts from Hogs at B'ville.
You should check with the late Leo Payne, Cook Neilsen and Warner Reilly from 1969. Leo and Cook had parts just like
those way back then.
To be original, you will have to figure out a new act. Hogs must be cannibalistic.
They seem to eat themselves.
John Noonan
Willie,
From looking at the dates on the pictures you had all of this year to fix it, what happened this year?
J
willieworld
the date in the camera is wrong ---i just took the motor apart this afternoon    willie buchta
Robin UK
I'd say that was Donald Ducked!! Think you might need a 5lb Irish screwdriver and a bit of body filler to go with the new rings.  :-D
Cheers
Robin
interested bystander
With all the recent banter about dimples on golf balls, looks like you've unintentionally dimpled the combustion chamber.
Maybe just do a valve job and bolt it back on as is. Ya never know. Might be worth a mph.
5 mph in pit area (clothed)
bbarn
I'm no expert, but aren't those "thingies" that hold the pistons to that rotating piece in the middle of the engine supposed to be straight?  :-o
What did that sound like when she let go?
