Spool or loocker or open rear?
Started by nutcracker, November 25, 2009, 02:46:46 PM
nutcracker
Do you run an open or loocker or spooled rear on the salt?
maguromic
It all depends on your preference and if you have traction control.  You forgot an open rear end as many run them also.  This debate is like suspension or no suspension and will get answers all across the board. Tony
jimmy six
Do a search...this has been discussed countless times. Good Luck
nutcracker
Thanks for your reply. Im new to this(dragracer) i have made a search now.
