Rain at elmo??
Started by mkilger, December 07, 2009, 11:13:24 AM
jl222
  Is the lake bed completely filled, like up by the main entrance?
  I wonder if the the BLM takes depth measurements? Tiny get your canoe and tape measure :-D
                         JL222 :cheers:
racefanwfo
The speed that you wish to achieve is only limited by the depth of your wallet.
Dean Los Angeles
QuoteI wonder if the the BLM takes depth measurements? Tiny get your canoe and tape measure
Canoe! That's a good one. As long as it has a one inch draft you should do just fine. I don't think more than two inches at the deepest point.
jl222
Quote from: Dean Los Angeles on February 06, 2010, 07:37:55 PM
  Wanna bet? :-D
I would bet it's at least one foot in the center of the lake bed and it goes shore to shore.
Dean Los Angeles
I KNEW I could get a response out of somebody! Didn't take a tape measure either.  :cheers:
Guess we will have to ask Calloway.
Old Gringo
Quote from: Glen on February 07, 2010, 12:53:04 PM
Just spent some time on Google Earth checking on the El Mirage Dry Lake. G E shows an area that is shaped like an arrow head pointing South East. The long dimension is approx 4.7 mi long. The widest dimension is approx 1.5 mi wide. This whole area is shown as being at 2838 ft elevation. SCTA property is at 2848 ft elevation. Sheep creek starts in the San Gabriel Mt and drain's North to El Mirage. I don't know how much rain from the mountains gets all the way to the lake. Depending on how much time it takes the water to percolate into the ground. It would take a lot more rain and snow melt to get a foot of water on the lake bed. I suspect the surrounding area would not drain much into the lake until there has been enough rain to saturate the sand and cause runoff.
Ex Hound Dog Crew Chief. Retired Xeroid.
TINY
There is a lot of water.No way to know how much without causing a mess of the smooth lake bed.Wind moved water around today and pete flew cover in gyro said it looks good.
mkilger
Tiny, you need to get your own gyro so you can fly around with pete. Doesnt that sound like fun? :|
desotoman
#55
Mike,
Here is what Tiny needs. He could check everything out pretty fast with this. And it would be fun too.
Watch it Tom. Anything with a prop is liable to cause trouble. :-o :-o :evil:
desotoman
Pete,
ROTFLMAO, I thought it would be OK since it is a boat.
TINY
There is no gyro big enough to haul me around.That airboat looks great. :cheers: :-o :cheers: :-D :-D
George Calloway sent me a note and said the wind is moving the water around the lake bed. This is good. Chance of more rain in the next couple of days.
