Rear fender streamlining
Started by racer x, May 16, 2010, 12:59:49 PM
racer x
   I have made a rear section in an attempt at cutting drag. Maybe it is a waist of time but it only took a day to make .I need the practice.
As always I want to stay in Modified partial streamliner  .
The rule says the wheel must be visible for 180 deg.
Photo 1 is what I have now. Photo two is what I think I need to cut.
racer x
Sorry Jon.I meant to post this in the ECTA rules section.
Is this rear fairing legal for Modified Partial streamlining?
fredvance
I dont know if ECTA has adopted tne new,2010 SCTA mps rules but it would not be legal with SCTA. No part of the rear rim can be covered. Also cant be past the rear edge of the rear tire, I couldnt tell if yours is past the rear edge.
racer x
ECTA rule is a vertical lint through the axle . Nothing behind that line 180 deg of wheel visible and no more than three inches behind the tire
tekebird
Eric, I believe that it cannot drop below the top edge of the wheel too
racer x
It dose droop a tad.
I need to trim this little bit at the back.
Beairsto Racing
Eric,
what is the material that you are using to extend your rear section, plastic or rubber? Are you going to use fiberglass to smooth out the transition between the existing tail section and the new piece. It will be interesting to see the results.
In '02 we made up a new tail for my Busa after running to the NAPA store to get some plastic mudflaps, tail length in the modified class was being enforced and I was too cheap to hack up the tail like everyone else. Lots of duct tape, passed inspection with it and made it to impound.
Cheers,
Scott
2 Club since '02
Sponsored by: Turple Bros.,
racer x
#7
   I tossed this together out of  fiberglass yesterday. I did not want to invest much time. It is intended to smooth out the airflow at the rear.If it works I will clean it up and paint it. Otherwise it goes on the Offering to the god of speed shelf.
I got the idea from a guy that made a smaller rear fairing and claimed a couple MPG improvement. That tells me it cut drag. SO I will try this.
It is held on with six screws. Mounting from the passenger peg mounts( Sorry nitrous bottle mounts ) and a bracket at the rear. I can remove it in seconds and test its effectiveness.
WildBro
remember, the rule is when you are sitting on the bike. So take shock play into account with body weight.
No need to trim it at the very back as long as you can see the rim.
aka: Tenno Celeritas
racer x
Thanks Bill .  :-D  And many congratulations . I was going to paint my new fairing "primer gray" I figure that is the new black at Maxton :cheers:
Cajun Kid
Now Eric,
There ain't no substitute for  "Hot Rod Black"  it ain't primer, it ain't "flat black" it ain't "semi gloss". It ain't "egg shell"  it's "SATIN BLACK"... ain't no gray or grey in it.. LOL.. :cheers: :cheers:
Tail looks good, trim it up a bit, sand it and paint it  YELLOW and pin stripe some Red on there for me...
Have fun this weekend, go fast, set a record or two and be safe.
See you in June
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
racer x
Thanks Charles. I think i will make another one and spend more than a day on the Buck. It all starts at the core .And this is a good thing to measure from .But it is not straight enough to paint. Just a test.
I am sorry you will not be at Maxton this weekend. I hope you enjoy your trip. Try not to think bout cars and relax .It will all be there when you get back Have fun.
Beairsto Racing
Eric,
What was the result of your rear fender streamling? Any gains that you can attribute your fender work?
2 Club since '02
There sure were gains -- he got me to comment on it, that's what.
Other than that, though, you'll have to wait for him to tell you the story.
racer x
I think it helped. Even running out of gas half track the bike went 108mph.  :oops: . And my best pre race speed was 110. I made 5 passes over that speed with personal best of 112mph.
Since my engine was not running right I have to conclude the fairing was a key factor for those speeds
