Scooter racing/time trials at El Mirage?
Started by John Noonan, June 01, 2010, 09:51:18 AM
John Noonan
Willie,
Better get building...  :-D
http://www.motorscooterlandspeedfederation.org/info.html
El Mirage Dry Lake
First Annual Motor Scooter World Land Speed Trials
    Sunday, November 21st 2010
    For Further Information Please Contact:
    Alan Spears
    (619) 852-6985
    alanspears@motorscooterlandspeedfederation.org
    General Information
    The Southern California Timing Association (SCTA) has been hosting land speed trials at El Mirage Dry Lake for more than 60 years. Their "Motorcycle Rules" requiring a minimum of 15" wheels preclude most motor scooters from participating.
    The American Motorcyclist Association (AMA) and BUB Racing host an annual motorcycle only world land speed event in late August at the Bonneville Salt Flat. We are working with Dennis Manning of BUB Racing to integrate motor-scooters into the 2011 AMA/BUB Bonneville program
    We are going to keep our first annual event extremely simple. We're essentially running a "run what you brung" speed trial for scooters only. Scooters have two small wheels! We're self-proclaiming this to be the First Annual Motor Scooter World Land Speed Trials, so if you set the highest speed in a particular class you will hold the "Motor Scooter World Land Speed Record" for that class.
    We're not requiring more safety equipment on the lake bed than you use on the street. The aforementioned race organizations require Snell-approved full-coverage helmets, one-piece racing leathers, leather racing boots and leather gloves. Many of us ride on the street with half-pot Davida or DOT approved helmets, goggles, gloves and athletic shoes. If it's good enough for the street, it's good enough for El Mirage.
    So following this line of reasoning, you needn't drill and safety-wire your crankcase drain-plug, replace your rubber valve-stems with metal ones, or wire up side and center-stands. To keep the playing field relatively level we ask that you use pump gas. You can add octane booster.
    We will not distinguish between 2-stroke and 4-stroke engines. Similarly there will be no distinction between carburetion and fuel injection. Scooters fitted with superchargers, blowers or turbos run in-class, but are designated "Turbo" and run separately from normally aspirated scooters. No Nitrous Oxide allowed. No "class-jumping". The class you compete in is based on your scooter's actual displacement.
    The classes for this first event are:
        50cc
        70cc
        100cc
        125cc
        150cc
        175cc
        200cc
        250cc
        400cc
        500cc
        650cc
    Scooters modified with Turbos will run in their own class for that displacement. Scooters equipped with sidecars will run in two classes: up to 250cc and 250cc and up.
    You are solely responsible for your own health and safety, and transportation to a hospital if you require emergency medical treatment. You must sign a written waiver before competing.
    We will run one scooter at a time over a measured half mile course marked by cones. We will designate a Radarperson and an Assistant Radarperson, both of whom will use new radar guns to record scooter speeds. Any discrepancy between recorded speeds shall be resolved by averaging the two recorded speeds. No appeals. No arguing with the radarpersons.
    Trophies
    Trophies will be awarded to persons attaining the highest top speed in each class. The records will stand until broken at the next annual event. No recorded speed at any other event affects the records established at the First Annual Motor Scooter World Land Speed Trials.
    Trophies for Scooter Land Speed Records will contain a "1st" place insert and be engraved thusly:
    125cc LAND SPEED RECORD - 1 PLACE
    MOTOR-SCOOTER INTERNATIONAL LAND-SPEED FEDERATION
    FIRST ANNUAL SCOOTER LAND SPEED TRIALS
    EL MIRAGE DRY LAKE, CA
    NOVEMBER 21st 2010
ol38y
   " You are solely responsible for your own health and safety, and transportation to a hospital if you require emergency medical treatment. "
I don't see this getting by the powers that be when issuing a permit.
Larry Cason
2010 BUB 1350 M-PG record
bak189
Larry, if you knew what Alan's normal day time job is.......I think he may well get the permit........plus of course he is a ex-sidecar roadracer..........and we all know what they are like...................................
Question authority.....always
John Noonan
An attorney...thats what we need on the lakebed, hopefully nothing happens because he might have to sue himself for damages.. :wink:
Alan E. Spears, Esq.
Attorney at Law
Alan Spears, a highly experienced criminal defense trial attorney practicing since 1975 is committed to the delivery of outstanding legal representation. Alan personally handles each and every case, and develops that most important Client-Attorney bond: one predicated on trust, confidence and respect.
Obviously any one with financial resources can retain a high-priced lawyer. Finding the right lawyer can be a daunting task, running the gamut from perusing phone book and television ads to following up on referrals from relatives, friends and co-workers. Most often the exigencies of pending court appearances necessitate clients making hasty and often regrettable decisions.
The most important factor to consider besides the obvious necessity of the lawyer being competent, experienced, selectively aggressive and effective is that he/she have your best interests at heart at all times -- not just when you hand her/him a retainer check or fist-full of cash.
Alan Spears is the lawyer you should call first for competent, effective, experienced representation with your best interests being his main and only objective! The consultation is free and, most importantly, you'll receive Alan's honest legal assessment without any high-pressure scare tactics to get you to retain.
Call Alan Now: (619) 852-6985.
My brother had a Cushman with a wheel on a stick, had a box for delivering news papers. Didn't corner worth a crap at least to the left. Sure hope a bunch of ding bats don't show up and screw up the lake bed.
John Noonan
Quote from: Glen on June 01, 2010, 03:57:58 PM
Amen....
Their "Race" is the weekend following the last Elmo of the year..
Dakzila
 "We're not requiring more safety equipment on the lake bed than you use on the street. The aforementioned race organizations require Snell-approved full-coverage helmets, one-piece racing leathers, leather racing boots and leather gloves. Many of us ride on the street with half-pot Davida or DOT approved helmets, goggles, gloves and athletic shoes. If it's good enough for the street, it's good enough for El Mirage".
Maybe it's just me.....but this seems scary.........
Not so sure I'd want to ride a 650cc Suzuki Burgman, on asphalt, at around 115 mph, with half-pot helmet and athletic shoes.....let alone at ELMO.
Ron B.
RichFox
Thats the good news. you don't have to. Nobody has to. They can wear full SCTA legal gear or just stay home. That's what I'll do. But it sounds like fun to me. Just the picture of me on a scooter would make most anyone smile
1212FBGS
well its gotta be safe a lawyer said so  :roll: good enough on the street with traction wait till the go ballz out on the dirt... i think im gonna go just to sell clean under ware.... my bet not a one of 'em goes 75mph
Kent
Dakzila
"Thats the good news. you don't have to. Nobody has to. They can wear full SCTA legal gear or just stay home."
But because they can, someone (maybe many) will just wear the minimum. Sanctioning bodies have rules for a reason...to protect the dumb, the ignorant and those who just don't know any better.
Ron B.
bak189
Hey Glen, why do you consider the people that will be racing their scooters "Ding Bats"....
What do you call the people that race bar-stools and skate-boards with V-twin power at Bonneville.....
landsendlynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
John Noonan
Kent,
I bet there will be scooters running faster than 75mph just not safely..
Dean Los Angeles
650 with a turbo is ok.
But no NOS.
Is this next?
jimmy six
Do you think they will have a trophy for the most lights and mirrors???????????? :-D
