El Mirage Car Mins for 2010
Started by LittleLiner, July 07, 2010, 11:33:28 AM
LittleLiner
Question - Is there a published set of El Mirage car minumums for 2010?  I was looking at the SCTA website and the chart I found was labeled 2009.  see ->  http://www.scta-bni.org/El%20Mirage/car_mins_table2009.pdf   Thanks   Art
Art, on the SCTA web site look under the El Mirage procedures it should be listed there.
LittleLiner
Quote from: Glen on July 07, 2010, 11:58:00 AM
AH HAH!!  there it is.   Right you are Glen (as usual :-D)
What threw me off is that the El Mirage menu has a choice for 'Car Speed Minimums' and if you click on that you get a copy of last years mins.
Thanks Glen
geh458
Being new to this sport, and only having attended one event so far, could someone please explain what this chart is for?  Iwas hoping I wouldn't have to ask, but I am unable to find a description.    Thanks.
Gifford Hawn
Vintage Sports Car Racer looking to convert.......
RichFox
At El Mirage we run for points which determines the next meets line up position. Your points are based on what percentage of your class record you run. If you are running in a class where no record has been established the SCTA has set a Minimum that you run against. If you exceed that minimum your speed becomes the new record.
geh458
Thanks, that makes a lot of since.  This will be helpful in deciding what class I want to build a car for, maybe get my name in the record book, at least for a little while.
Gifford Hawn
