XXO/BVGC '38 Chevy Coupe Build
Started by 38flattie, July 21, 2010, 06:34:16 AM
38flattie
#165
We hope so Richard!
Ok, a couple of thanks here!
To Skip Pipes, for the awesome intercooler/chiller and water pump! Pics posted previously. :-D
To Tony (Maguromic) for his wonderful avatar! :evil:
Oh yea,Tony,and for the great heated dry sump oil reservoir! :-D
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Nice dry sump tank. From outward appearances it appears to do everything right. :-D :-D :-D
38flattie
Nothing glamorous today, but necessary, none the less! Here's what
Randy sent me:
Well here it is 10:30 Sunday night and I ran out of welding wire so
here is some pics of structure repair and rocker replacement also note
that the doors now fit lol. So tomorrow after a trip to the welding
store ill get the driver side finished welded in an move on to firewall
replacement which I am looking forward to.
Rust repair
38flattie
Drivers door before, and both doors after.
38flattie
Ok, so we'll end up with a 14.5" (13%) setback, and the firewall will be setbck 12"
38flattie
I like the engine placement- down low and back! :-D
38flattie
When I logged onto the computer this morning, I got a pleasant surprise! I received this email, and pics, from Randy :
I was able to get in the garage tonight and made some good progress here are a few pics. I got the firewall tacked in good and was able to get a little more setback we're now at 16 1/2" that gives us about 1" between back of the block on pass side and the firewall which is plenty of room.  I also rolled some beads in the firewall hope you think they are ok.  I also was able to get the motor mounts set in and the trans crossmember started I should be able to get that finished tomorrow and then I will get the injector hole trimmed out and keep movin on
I can't wait to get home and work on this!
38flattie
Ok, tires have now all arrived! I don't know why this excited me so much, but it does!
Gary Hart's knee is bothering him, so he is not able to do the roll cage. He and John were kind enough to recommend Sam Woodard, who did much of Hooley's cage. I took the car to Sam on Friday, so we'll have a complete cage soon!
In the meantime, much of the work is boring rust repair and body work. The mock up engine placement is done, and the cowl has been cut to accommodate the bugcatcher.
38flattie
#173
Back in Ohio, Dale and Chris have been busy finishing the head design. :cheers:
Quote from: 38flattie on February 20, 2011, 10:16:55 AM
It's all a part of dealing with antiques, but when it's done, despite the bloodied knuckles and the shop floor covered with silica and steel dust, it's worth the effort.
I don't know how much rake you're putting on this beast (this is a beast, by the way  :-D ), but I'm thinking this might improve your ground clearance at the bellhousing. (?)
Very hip build - looking forward to future posts.
Chris
What does the other side of the head look like??
CNC machining has really expanded what can be done these days and your two piece heads are a great example of something that could not be done until CNC became available to the general public. Those are going to be some nice parts!
Tman
They are being sneaky and wont show the combustion chamber :-D I dare ya guys
38flattie
#177
Chris, your 'beast' comment made me laugh out loud! I often refer to the Flatcad as 'The Beast.! Thanks for the kind words about the build !t's been a fun build, although a bit stressful, with all the changes we've made.
I should have measured the overall height, but I venture to guess it's around 54". Pretty short, and sits low, clearance wise! We have 3" of rake, with 25" tires front, 28" rear. This leaves us with 2" clearance at the bellhousing.
So, is 2" enough, or do we need more?
Rex, I sent you an email explaining that we won't be posting the chambers until after we have tried them. I will post pics this fall! I'm already working on the next version (OHV) of heads, so these will be history anyway.
Trent, you know I like a dare, but will have to pass on this one!
Tman
I would pass as well, gotta keep at least ONE ace up yer sleeve :-D
BTW, that car has awesome STANCE! reminds me of a Silver Supergas 37/8 that was around in the 80s.............which I think was spotted up here on teh 1/4 mile last summer, gotta dig out the mag................
Way to go guys, just doing small,non photogenic work on ours these last couple weeks.
GH
Buddy, 2" at the bellhousing? The oil pan is probably about the same distance from the ground. Be careful loading and unloading the car off and on the trailer and don't smash the oil pan like I did.
