Australian Belly Tank
Dr Goggles
#1605
very clever MM :-D
I'd like to add that this motor was built after a discussion a few years back with Jack Dolan who said a long duration cam with slightly more than stock comp could do what we wanted to do, be affordable and go the distance.Some people questioned what we were trying to build , so far it's making power in the right place. We 'll see if it does the bizzo.
Tomorrow we have a flat out effort to put the motor in in and assemble the car before we leave the next morning.I finally sorted out getting the car on the truck and I've been working out how to properly secure all the other stuff we have to take.
later :wink:
Quote from: Dr Goggles on March 16, 2011, 04:43:15 AM
later :wink:
Doc, have you also sorted getting the car off the truck in a remote environment?  Good luck on the thrash, I think you guys have it on the right track.
Dr Goggles
Quote from: Stainless1 on March 16, 2011, 06:34:06 AM
We have four stands that support the car at working height, (the tub won't come off without them) and an A frame we use to lift it and/or the motor .I welded a perch onto two of the stands at the height of the tray and will support the ramps at that height after hoisting the rear of the car..it means we can leave two of them at home because the ramps will work as a platform if we need . I'll still have to take extra ramps ( in order to get in ON the ramps AND over the bend in the beavertail)but I'm pretty sure it'll go on and yes off now Bob with some applied bother.It's here where a tilt tray would be nice.....
Gonna be a busy day.
Drewfus
thinking of you guys (and all the other racers), yet again wishing I was going, keep safe
"Build it small, Drive it BIG"
Dr Goggles
Hey Drewfus,
pity you can't make it.
We assembled everything yesterday and fired it up.it sounds mad.
Right now we were going to be on the road but we've been behind for a bit and the Colonel has given it an almighty shove spending three days at the dyno.He's been healthier than he is right now so we've inserted an R&R day. I still have to pack and sort the tools, the camping gear and work out how to secure it all to the truck.
Speaking of dyno Mat Cavalli went way over and above what we could have expected from someone who hasn't suffered along with us , he has his own workshop in Shepparton and knows his onions for a young guy, he was the man responsible for the chip we'll be running.Thanks also to Ian for the dyno and all the time , he's got a half finished tank there and I'm expecting to be on-call for tank related questions........
The was an insurmountable issue with the program in that it refused to rev beyond 6400, If I can't find some 30 inch tyres to borrow on the lake then I will be fitting the little "cheater" guards we made last year and run in streamline class.
I'll be back.
Elmo Rodge
James, I forget. Will you be out of earshot on the Lakebed? By the way, drive real fast and have gobs of fun.  :cheers: Wayno
Reverend Hedgash
#1611
Yes. Here I would like to say a bit about the Colonel.
As he says, "They make it, I make it work." What that doesn't say is the crucial aspect of when he makes it work which is the critical time that it requries to work. At the salt he has regularly diagnosed then created a very workable fix to unforeseen issues which otherwise would have ended our run.
This week the Graham went over and above the call of duty to get that engine to work, to have power and be ready for Speedweek. And as Dr.G just mentioned, he certainly isn't in the best of health this week so that effort is so much more appreciated. Rest Well, Colonel, we not only want you there, we need you there!
Also big thanks to Mat and Ian, if we didn't have this Dyno session and your help our run at the lake this year would be very short indeed.
The engine still ceases to accelerate mysteriously at 6400rpm but I know all these guys tried them damnedest to find out why.
The important thing though is we have an operational engine to go racing. Maybe Dr'g will not get his 200mph with it this uyear, but I certainly can get my 175mph pass (yes, practice those gear changes...) and then push the F for fuel record up to close to 200mph. That is an improvement.
With the cheater gaurds on we get to set a host of other records.
But we must also remember it is not just about records. Its about being there as a participant, and enjoying and learning from the runs.  We don't get enough time in the car to become expert at driving it, so just being there this year with an operational car makes this happen.
Thanks to all who have helped make it happen.
Raining today near the lake, forecast not great, but we are ready to go should it be on.
Keep the shiny side up indeed, that's the Spirit of Sunshine!
Reverend H+
"Is it because they are lucky that they become great? No, but being great, they have been able to master luck."  Napoleon
Have a great event.
Be safe, go fast, and have fun.
:cheers: :cheers: :cheers:
Kiwi Paul
 :-D And the Saga Continues......It`s not usual for Kiwis to wish Aussies luck and good fortune in much, team, but I surely wish it for you lot. Hope you give em hell... :cheers:
racergeo
      Good on ya Googles, you the man! But were goina hafta yak about that engine of yours. You should be able to rev the buggery out of it with a roller cam. Generally speaking ,two things hamper revs, valve springs and fuel volume. Any way, like the Rev said you'll learn some more, get some licenses and have some FUN. By the way, Ians gettin a bit of an awning over the toy shop,eh.
HEY!  :-(
HEY! :|
HEY! :-o
Those dirt bags snuck out of town without showing us the finished product!
:wink:
grumm441
M.M.
We haven't left town yet
http://www.dlra.org.au/forum/viewtopic.php?f=1&t=1527&start=137
Headgash took some photo's yesterday of me coughing while Goggs was spannering
Wayno. we are incommunicado about 10 minutes after we leave the bitumen. about 90 miles from the lake
Dr Goggles
Quote from: racergeo on March 17, 2011, 09:36:48 PM
      Good on ya Googles, you the man! But were goina hafta yak about that engine of yours. You should be able to rev the buggery out of it with a roller cam. Generally speaking ,two things hamper revs, valve springs and fuel volume. .
Hey George our pump is one of those big Boschs, it'll support 650hp..... the valve springs could be an issue but our last motor had turned over 7k in a previous incarnation...WITH A DIFFERENT ECU.
there is a forum here that has a section devoted to these motors and there's a couple of guys who know their linen, or rather their sheet....here is one theory...
    why wont it go past 6400 no injectors left or fuel pump not keeping up or is it tapping a limiter you probably need to use vl400's custom code that lifts the VE table rpm all the way to 9600rpm so you can tune that high the formula holdens had doctored code to allow them to do things the stock ecu wouldnt allow
Drewfus
rest up colonel and take it steady, with the uncertainty of the weather there is no rush, keep safe first and formost.
"Keep the shiny side up indeed, that's the Spirit of Sunshine!", yep, rock on.
Looking forward to hearing about your endeavours when you get back.
Cheers,
Drewfus :cheers:
