Australian Belly Tank
nickleone
Sorry had laksters on my mind.
Small moped powered car from the 60s'. i believe it went around 50 mph. Was in Hot Rod Mag coverage.
Drivers head was in the front in a prone position.
Nick
As I recall the owners name was Alan and he donated cases of wine.
Maybe Langlos remember him.
I know Rochlitzer would.
Dr Goggles
Quote from: nickleone on June 16, 2011, 08:22:30 AM
This is a SMALL lakester.Nick
I think that's what they call a suppository.
grumm441
It would be banned now
Driver prone, tyre speed rating
Dr Goggles
I had a bit of a clearing sale courtesy of the large online auction site over the weekend.
I got 65 bucks for the Prefect motor. A father and son came to collect it, nice enough, they overstepped the mark a little when they saw the other bits and pieces I had for sale......They'll be back, with a little more cabbage than they offered me for some of the remnants.Who knows or cares what a Prefect door is worth but I do know that fuel tanks in good nick are worth money whatever they're from...... I'm looking at covering the cost of what I bought which I thought was a bargain anyway....that doesn't happen everyday as you all know.
Sideshow
Reverend Hedgash
I am in Hong Kong at the moment and presented to a company that made 15 billion Hong Kong dollars on one deal recently which allows them to play with the big boys... strangely the deal wasn't shonky.
rH+
Dr Goggles
Shonky deals indeed.....finally after getting very close recently I've found the rear gear set we need.....
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=110710523786
The dirt track guys buy all of these apparently, not this one but.
Gears, tires - it's all falling into place.
Welcome to the Mall of America!
That overhead compartment's going to be a bit full, especially if you score a used Nudie suit.
Reverend Hedgash
Good work doctor, very quick on the draw.
Here we go, here we go, here we go!
Tank day this weekend?
d
Dr Goggles
Quick on the draw alright, it came in as a notification email, I didn't even think about bidding...buy it now!, buy it now!....
I think it had six views. The last guy who offered to take the money never got back to me despite a bit of prompting....
On another front I have to pull the axle insert out and take it back to the machine shop for a skim, it's all a bit tight which will give me no "shimmy room" for when we try to get the pinion height and alignment right.....
Dr Goggles
We got some way into the job to fit the housing for the ten bolt rear end.
After having a crack at pulling one of the inserts in last week we elected to have a closer look. It seems where the axle tubes were welded into the frame that they were pinched a little by the cooled weld. We took to that with a stone and then gave it a polish with a flap wheel, on the next try the progress was a whole lot more even.Next we had a look at the housing itself. due to the way things had to go together we needed to pull the inserts from inside the housing, that meant there had to be a clear path. Turns out that the machining wasn't perfect and the axle "hole" didn't line up exactly with the relief behind the bearing seat so there was a bit of de-burring and clearancing there too.
So, we've got a three foot piece of half inch rod with some 8.8grade 5/8 thread welded on either end and a bunch of thick washers, short pieces of pipe and other assorted items to use as spacers.....
The idea is to pull the insert from the inside of the housing into the axle tube, the end of the insert that fits the housing is slightly larger than the end that goes into the axle tube, we put a chamfer on the step where the dia. changes just to stop it "ploughing" anything. Once we got both sides started we decided we needed force on both  at once or it would just be a see-saw so we quickly knocked up another length of seamless tube with a bolt out either end and got started.....there was a bit of tension in the system at this point, and we had noticed that the "legs" which wrap around the axle tubes were pulling inwards...they're half inch steel....In the shot below you'll see the ends of the puller rods inside the housing, you may also notice that the washer on the right is buckling......
The movement had been slowing, the force applied increasing......we paused to assess...."so,where is it moving?"....I gave it a few more turns and there was a resounding TWANG! followed by some tinkling of parts, the washer on the right had given up the rod pulled through the middle of it and the washer went flying, we figure from where it ended up that it went between the Reverends legs.......unseen.
Nothing was broken, the legs had popped back to straight. I figure we need to use a porta-power to push the inserts from within the housing as well as pulling them.
On a side we cut some nice holes to plug weld the inserts into the axle tubes, I think they are a leeeetle bit wide....hmmmmmmmm
All in all though we made slow but effective progress, I'm yet to research the availability/compatability of the universal joints on the tailshaft and haven't bothered working out whether we'll need to lengthen the tailshaft, if we have to shorten it there's gonna be problems, there is only about an inch and a half of tube, that means we can probably only shorten it 3/4 of an inch...... as it sits though it seems to line up pretty well(not perfect here but well within limits),
we have plenty of side to side adjustability, we need to do a trial fit to see that the stock Ford axles will be the right length with the centre in the centre or so to speak.
This is just another example of "you had to be there to understand why we did it this way".
Geter done so we can find out if we need to bring you another housing or not :-D
grumm441
So I should bring my porta power over
