Australian Belly Tank
Kiwi Paul
Biscuit???!!!! Actually, I`d even settle for a Violet Crumble....oh I know, Sid, it`s sacriledge to one up a Crunchie.....Gingernut and a Cuppa Choysa it will have to be... :-D :evil:
Doc, it's already a contender.
+- 1mph/79 rpm between runs is an insignificant comparative stat at 215.  And if you can outaccelerate the push truck, it becomes more of a nod to formality than a necessity.
I need to catch up with Bob Bleed before he takes off to OZ for Chopped - make sure he sees the tank.  Anything I might be able to throw into his guitar case for you?
#3902
DR. G  I get it that is the chicken or the egg thing but we have to get that eng turning 7-7.2 sometime ---.I know you know the trade offs!!!!
UPDATE:
I just went to one of my dream charts and plugged in:
2.28 and 28" ---230 at 6300
2.41 and 28" ---235 at 6800
NOW I get it--- see if it can get there with the hp you know you have NOW  or you will know how short you are
". . . because if you build a high-revving hi-comp motor and break it, you'll never be able to afford to build another one". Jack Dolan
Bill, let's have an argument.  :cheers:
This is not a hi-revving, hi-comp engine.  The bottom end is remarkably stock, and while it has proven itself reliable, I don't think it will take 7k.
If we were splitting logs, I'd take the sharp wedge and the lighter hammer.  You'll split more logs, and you won't wear yourself out.
SOS is a sharp wedge - I think it can be done with the gears.
Now SOMEDAY, I'm going to convince them to buy that Menard Indy engine and stuff it into this.  At that point, all bets are off.
:-D
MM I am sorta with you and Doc-- if we keep gearing up until we can't pull it the we will know where we are HP wise the the option is the other way
grumm441
Quote from: Milwaukee Midget on September 05, 2013, 09:00:35 AM
:-D
Or maybe finance it
Grumm   :evil: shoot for the big marble---sponsorship or at the very least---eng. partner  :-D
The issues you are dealing with are what I am wrestling, too.  There is a tipping point where naturally aspirated power becomes very expensive for limited increases and enhancment becomes the most cost effective alternative.
Dr Goggles
Quote from: SPARKY on September 05, 2013, 08:35:02 AMUPDATE:
Yup, that is the point I was trying to make. It still seems we have no wheel slip. It seems that the car ran the two speeds at the same point on the track. Had we been able to accelerate using 1st and 2nd gears I feel we would have shifted into top maybe a full half mile before I did. In 2010 we were still accelerating in the last mile before the motor would nose over. We had none of those issues, we were running over twenty miles faster two miles sooner!, I strongly believe the Haltech will let us put another 250-300rpm on what seems to be the current ecu imposed recline of 6350 by way of the fact the the power curve drops dramatically, the design of our motor would tend to indicate that would be the point that the curve was heading north ,not south. Another important point is rather than slogging down the track at 3-5000rpm in 3rd we will be able to use the 5000-6500 range in 1st and 2nd before hitting 4th in the high 4000s... Am I making sense?
Speed Limit 1000
[quote author=Milwaukee Midget link=topic=862.msg232184#msg232184 date=1378396835
:-D
[/quote]
Check with Stainless, he has a Menard Indy motor.
Jon
Quote from: Dr Goggles on September 05, 2013, 06:47:52 PM
Am I making sense?
Ummmmmmmmm................... Yes
Seal the scoop.
Underhouse Engineering
Dr Goggles
Quote from: Speed Limit 1000 on September 05, 2013, 10:00:29 PM
:-D
[/quote]
Bit soon Johnboy,bit soon.
I see this one is still available -
http://www.race-cars.com/engsales/other/1348602323/1348602323ss.htm
It's only got 4 hours on it.
Given the history, you could easily squeeze another 20 minutes out of it . . .  :-D
grumm441
From a previous post -
Quote from: Milwaukee Midget on November 07, 2012, 01:46:51 PM
Quote from: grumm441 on November 07, 2012, 01:36:14 PM
Quote from: Milwaukee Midget on November 07, 2012, 01:30:03 PM
Quote from: Reverend Hedgash on October 27, 2012, 06:42:57 AM
I could try to hunt down a Menard Indy engine for you - probably bolt right up.
errr... really? I just looked it up and as a rev limited 10 000rpm  buick 6 it could indeed just bolt up and blast us into history.
I can't imagine there is much use for them these days... how much do you reckon?
rH+
I think that price is quite high given the limited possibilities for it.  I'd offer them 6.  Probably be the only bona fide offer they would have received for it.
Ship the car over with the old donk, swap it out in the parking lot of the Nugget, and away you go.
That would do it
Now I just need to find some spare cash
I'm currently getting quotes to have my asbestos sheds removed
What some of these guys want to remove this stuff would be a significant down payment on that engine
It's only a 5 hour drive.
Want me to grab a camera and tape measure?
I'd be willing to clean out a corner of the garage until you picked it up/made arrangements.
That offer still stands.
They ARE temperamental, but dial back the boost a bit, and I suspect it would be quite tractable and long lived.
Realistically, including dyno time and machine work, it's cheaper than my Formula 2 spec BMC.
The big downside is that it's set up for fuel - I don't think you have a big enough fuel cell to get to the 7.  But on gasoline with the boost turned down, I think 500 hp would be easy and reliable.
We can swap it in at Wayno's.   :cheers:
