Australian Belly Tank
Elmo Rodge
Thanx Grumm. It is however not 'til next Friday.  :cheers: Wayno
It sure is sounding sweet from the cheap seats -
http://www.youtube.com/watch?v=WMWPu5BjWZM
I'm trying to listen past the Doppler effect.  That seems like a steep shift into high - pitch dropped almost a major 5th.
1.23 3rd gear?
Dr Goggles
1.23? I wish, 1.32 from memory,sold to me as a 1.25 :cry:.... A close ratio box is so obviously needed when you're in the basement ratios that we were running last week.
The empty pit with the shade cloth in the foreground of the shot after I go past is the salubrious SOS pit,not quite the WGB.........
OUCH - That's a steep hole to pull out of.
You may well have had enough power, but simply fell off of the table on the gear change.
Engine sounded good from a distance - wasn't shooting ducks, anyway.
salt27
Goggs,
         Where's the report we've been so patiently waiting for?
You will be at B-ville SOS or not, right.
Back to work for you.   :-D
Dr Goggles
Patience? You young bucks obviously have a different understanding of the word. I have fifteen hundred words and I'm only up to the first run :wink:
Dr Goggles
Quote from: Milwaukee Midget on March 10, 2014, 01:53:21 PM
Yeah,it never seemed that big before, I changed at 176mph....then ,meh........
Give us chapters on the story, we don't need it all at once.  Will build up the drama!
Quote from: Dr Goggles on March 10, 2014, 02:49:51 PM
So then did you get to try one of the lower gear ratios?
stay`tee
for what its worth Goggs, on that 204 pass i watched you go by the pits and thought to self, "he's up against it",,
grumm441
It did 186.955 with the 2:14's on Tuesday
It did 204.07 with the 2:14's on Wednsday
then 179:272 with the 2.28's on Thursday
Was running rich off it's tree all week (Aussie expression)
and I am fairly confidant that the Battery Isolator died during thursday's run
We also had some other odd failures that we fixed during the week
and there aren't many photo's because our sponsor, Competition Coatings in Coburg, gave us a really nice
silver foil cover to put over the car to keep it cool. Last year, by thursday morning, the car was too hot to touch.
salt27
#4346
Grumm, Were you able to smear Copper Cote on Goggles arse again?   :cheers:
Dr Goggles
Quote from: salt27 on March 10, 2014, 07:49:59 PM
Grumm, Were you able to smear Copper Coat on Goggles arse again?   :cheers:
Good spelling Don,and no........
Sum, we have run, 205@2.56:1@6350rpm  215@2.41:1@6350rpm
179@2.28:1 * failed run
204@2.14:1 @5285rpm
salt27
grumm441
What smear, I have it in a spray can
