Australian Belly Tank
Dr Goggles
Well, I haven't taken that pump apart again but you're on the right track. I bought two big bits of fuel foam a few weeks back...today I cut the top out of the fuel tank. Just to recount, the tank is Al, and epoxy lined.....I didn't have a sock filter in it but did have a deep cross piece over the outlet to try and defeat vortexing. So anyway I hooked a hose up to the outlet, filled it with water and cut the top out leaving a 1 inch border.Lo and freakin behold, when we look inside there is about a pint of epoxy sitting in the end where the outlet is...the tank has been left to sit on a 45 degree angle before the goo has gone off , completely covering the cross piece, and filling the "sump" area of the tank........then a drill bit has been run up the outlet......top effort....
The Colonel is going to make a gasket and screw down the plate we've made for the top, and then attach the piece with the filler neck to that, stuffed full of foam we should be fairly confident that it won't cavitate... We're buying a slightly smaller pump than the 044 which is bigger than we need.
I cleaned up and touched up the paint on the wheels, just a brush , rough as guts because the wheels have discs on both sides.
We found that the last surviving 1.5kg Cold Fire cylinder had carked it...corroded through. We're going to run one 4 kg cylinder for the fuel tank, sump and upper engine bay nozzles and keep a single 1.5kg cylinder for the cab.
We have decided to change the way the chute release operates. At the moment the doors are loaded by the drone spring pressure, this runs the risks of the doors opening accidentally and also means that sometimes the catch jams. We have decided to try and use a strap arrangement to retain the chute and drone and have the bay doors kept closed by magnets, when the pin is pulled it will release the strap allowing the drone to open the doors and pull the chute out.
I gave the screen a cut too with some 800 1200 and then 2000, I'll finish that when I run a buffer over the car as it goes in the trailer.
We also began to work out a better way to organize the canopy hinge....the current arrangement is made so that if the car is upside down the canopy pins can be popped and the canopy removed, but it tends to come of the ferrules which keep the pivot points aligned and allows the canopy to fall too far forward..
We've got 60 days.
grumm441
So apart from that you can see by the board
We have also put a new battery in the clock on the wall
It's fun to read about the "youse guys" begining thrash--glad you found your "likely culprit" on the fuel issues!!!!!!!!
Dr Goggles
Sparky, your name came up yesterday. I told the Rev about your two motor different trans 4wd deal....he kind of glazed over......"huh?, wha?".............
we had beer too. Now, I'm back sitting at my desk, in nice clothes.....wondering where the last two weeks went...and wondering how I'm gonna get everything done AND get to the lake AND run 200mph...... :wink:
Quote from: Dr Goggles on January 03, 2010, 02:27:52 PM
..... wondering how I'm gonna get everything done AND get to the lake AND run 200mph...... :wink:
Persistence...  8-)  :cheers:
robfrey
[/quote]
Sleep less, eat less often and faster, work off a single "to do list" whiteboard, surround yourself with people like BBarn that keep telling you "we can do it!"
That's what works for me. love your project, can't wait to hear what it does.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Dr Goggles
Quote from: robfrey on January 03, 2010, 07:50:37 PM
That's usually my job,  :-D , baseless enthusiasm, unshakeable confidence in the near impossible and a seeming inability to accept the inevitable, listen to a sensible voice or for that matter a voice of reason......
almost perfect for this sport... :wink:
grumm441
Quote from: Dr Goggles on January 03, 2010, 08:20:35 PM
And then there is me
"Enthusastic PRECISTANCE Patience"
  and in the words of one of your "Pommey"{ may not be correct usage} cousins  "Never, never, never. never surender"!
We are sort of like you guys.  We can't get it all done on time, and we have seven months.  Its not lack of time to work on things.  Its not enough time to save up the dough, buy the stuff, install it, and test it.  I won't run an engine unless it is broken in.  We will have everything done except the cam and pipes and we will probably go slower this year.  We tell our sponsors and fans that this is a "development year."  That way, if we go faster, its OK, and if we go slower, we have a pre-made excuse. Either way we will run and have a good time.
Dr Goggles
Hey, we'll be there....it's just that I never understand how it DOES happen.....the motor ain't built, I don't even know what I'm driving there, fire system...gotta be retested, reconfigured, ....check out the "to do list" on the photo above ....lots to do, it will be done , we will be there......we'll come home with a hat or a heap.
58 days. :wink:
Working from a list is good, but our problem was always you clear 1 and add 2... prioritize necessity vs want
good luck  :cheers:
grumm441
Dr Goggles
#868
......and like you said...."and then there is me"........ , so anyway, thanks for maintaining the facade that we're serious, sensible, and focused on the "sharp end" of landspeed racing.......I think you should avoid taking holidays,or if you must then spend the time meditating, or indulging in the dark art of porting.
EDIT: Cripes! I just noticed ....are you wearing a sports bra?
 :? ROTFLMAO!!!!!!!!!!!!!!!!!!!
