NACA 66 Special A/BGS
Started by robfrey, September 23, 2010, 06:12:28 PM
saltfever
I'm anxious to see the changes Blue mentioned in his post #57. Good description but you know . . ." a picture is worth . . . "   :-D
robfrey
We got some wise advice from current record holders that if it was at all possible, move the driver rearward  so that he will have a better feel of what is happening. We were then able to go back to the Goodyear 2222 tire in the front. We have a lot of work to do cadwise but here are some pictures so far.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
bvillercr
How fast do you guys plan on running again?  The Goodyear 2222 from what I understand is rated at 300mph, although we have had them higher.  Also not sure how it would be for a front tire?  Good luck with your build. :cheers:
robfrey
Sorry,  wrong part number. I need the 450mph goodyears like the ones on the Speed Demon.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Jonny Hotnuts
Not talking smack but I am concerned about the COG/COP relationship with this configuration.
Ever consider vertical fins off the rear wheel covers (*similar in setup to a F15)?
-BTW:
Great job RF....
~JH
jonny_hotnuts@hotmail.com
*Andres Segovia
Jonny Hotnuts
-also, it may of been mentioned but what engine configuration is planned for the vehicle?
~JH
*Andres Segovia
joea
..so johnny, where did you measure/calculate the cog.....?....and the cop....?....
I think it is pretty easy to just look at Rob's drawings and you can tell that the CofG (center of gravity) is well in front of the CofP (center of pressure). The engine is going to probably be close behind the drivers cockpit and probably most of the liquids, water, oil, fuel will be ahead of the driver and with the big wheel "spats" the CofP is most certainly to the rear of the car.
joea
yes Rex, but i was curious what johnny was pondering...after reading his query...
saltfever
#69
Actually, Jonny may have a point. Excuse my inept use of Word Draw but just threw this together. It would be great to have a nice CAD system (and the skill to use it) like Rob.  Assume the CG is located as indicated. Now compare the amount of surface area in front of the CG compared to the surface area in back. CG and CP look very close. No way of telling exactly from here but Rob's CAD program can calculate the area exactly. CG/CP location might be worthwhile to look into. I have no way of knowing the CG location and it can be moved by relocating various mass as Rex mentioned. But those wheel covers do offer a good location if you have to add area to get the correct CP relationship.
PS: Enlarge the picture to see where I put the CG.
joea
salt fever....there is NO WAY they would allow the cog to be there....
Do front inline wheels have a greater resistance to directional change than side by side  :?
JoshH
Quote from: saltfever on October 20, 2010, 12:01:50 AM
I don't think so. There is a ton of area out back. Consider the area of the wheel covers (inside/outside) and the airfoils (top/bottom). Lots of surface there.
Blue
OK, time to chime in.  Yes, that CG estimate is pretty close.  As JL222 and many other highly successful LSR racers have pointed out, it is good to have the weight as aft as you can stand it for traction.  My job was to come up with a configuration that allowed a mid CG to be highly yaw stable.  Al Teague and Craig Breedlove had done this with very similar configurations, so that's where I started.  Far from this being some wild hair I pulled out of my a--, the configuration is based on actual, record setting, stable jet and wheel driven cars.  We just moved the rear wheels out further than Al had them and moved the wing onto the rear axle.
The Cp (yaw neutral point) is located 3 to 4" aft of the leading edge of the rear wheel fairings.  Three things that put the yaw neutral point father aft than expected from looking at the side view are (in order):
1. There are two tails.  In the side view we only see one.  For a back-of-the-napkin Cp, stack the second tail on top of the first one and then look at it.
2. Wing sections are neutral at their 25% chord point, while rounded objects (like the fuselage) are neutral further aft.
3. The Wheel fairings have span (vertical) and end-plate effect (the ground) that make their effective aspect ratio between 1.5 and 2.  The fuselage has a lateral geometric (side view) aspect ratio of less than 1/10th of that and since it is rounded on the top and bottom and up off the ground it's contribution to yaw is only 2 to 3% of the effect of the wheel fairings.
The stability margin is 2 to 10X that of any of the current 400 mph club, and with the wing and adjustable flap we are looking for more than enough downforce on the rear wheels to exceed our available power.  All of this comes with very little separation (exposed tire sections are about it), minimal wetted area, and lots of laminar flow.  I'm not just designing it, I'm building the bodywork;  so we'll see.
JoshH
Quote from: Blue on October 20, 2010, 10:31:19 AM
The exhaust outlet could be tricky; its likely going to have significant interaction with the airfoils. Also the configuration makes the parachute packaging and deployment challenging.
I won't ask about frontal area...
