NACA 66 Special A/BGS
Started by robfrey, September 23, 2010, 06:12:28 PM
#870
Congrats guys looks like some pretty happy air back there  :-)  Does Eric think the rear wheel fairings  or the main body is causing the chute to fly to the inside of the turn?
Good data, those QC's are noisy. the chute looked great, also looked like good straight runs, love it, just think how much fun the salt will bring. :cheers:
bbarn
Quote from: SPARKY on September 30, 2013, 10:55:37 AM
sure does! That exhaust is nowhere near the velocity it will be on a high speed pass, we made no boost at all. The black smoke was due to a 140 degree peak block temp and 36 degree inlet air.If you look closely, those exhaust plumes are clearly re-attatching at the tip of the stinger.
Granted we had no flap applied, so this was a clean aerodynamic profile. It is interesting to view though, it looks like the exhaust gasses are forming a 12" cylinder that follows the car very consistently and without much turbulence.
bbarn
The chutes were blown to the right of the car's path by a fairly stiff breeze. If we had slowed just a bit more and the chute deflated before the turn we wouldn't have picked the taxi light off.
Jon
Congratulations guys, another very successful step.
Lots of valuable data and familiarisation that will set you up for a good "first" crack at the salt.
I can only imagine how disappointed you all were not to be at the salt this year but its all going feel very natural by the time the salt is ready for you next year.
jon
Underhouse Engineering
desotoman
Congratulations on your outing.
And a big THANK YOU to Sparky and JoeA for the loan or ? of the tires which made this possible.
Dr Goggles
AWESOME!!!!
The way the exhaust leaves the tip of the tail says it all, sensational car that.Great to see everything coming together so well. Congratulations again.
gkabbt
Brandon, just posted this in the Wilmington Picture Thread:
In the second video it looks like the top of the wheel covering is moving around as speed increases.
Is it just me or does anyone else see it? I don't think the camera is playing tricks because I don't see it anywhere else.
Gregg
I see it but the vehicle is rigid mounted in the rear and could be track surface causing the flutter, might need a stiffner added. The front view wasn't that clear, it could also be the camera mounting.On the vesco liner we have two forward and two facing aft. adding one more in the cockpit as well. They really tell a good story of our runs.
tauruck
Rob, I watched both videos. Nice stuff. The car looks great. What a job you guys did!!! :cheers:
robfrey
It's definitely not the wind causing movement on the wheel fairing. It was the bumpy ride. Overall it is very smooth and I'm certainly not complaining. No way around those expansion joints. I can't wait to get back to Wilmington next year for more testing and to get Brandon in the car. We probably should have let the air pressure of rear tires down to 50 from 90psi. Would have rode much smoother. Never even thought of it.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
robfrey
We are considering El Mirage but wow, that's a long ride.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
El Mirage is a long trip and IFFY this time of year. You would be restricted to the full drivers tests and if lucky to get two runs in. As november is a two day meet maybe 4 runs. The lake bed is pretty soft and bumpy at times. If I were you continue with the testing at Ohio then to Bonneville.  :cheers:
Finallygotit
#883
I agree.  And if the winds crank up at Elmo in the afternoon, like they usually do, you will have even less time for runs.
Dan
Tucson, AZ
joea
good stuff Rob...on the "smoothness"....good the way you tested...more "real" world...in that Bonneville
wont generally be "smoother"....and the speeds MUCH higher as well as the accompanying forces....
