Goodyear Frontrunners
Started by LSR Mike, October 15, 2010, 08:26:57 AM
LSR Mike
Ok, I searched the forum without an direct answer, and I know a lot of people use Frontrunners.
The Question:
The Rulebook says VR or ZR Rated OEM tires for over 150MPH(which I have finally exceeded).  oodyear doesnt' show a speed rating for the Frontrunners (P/N1961).
So, do they qualify under the "special tires for racing as designated by the manufacturer" line in the rulebook for over 200 MPH in section 2F?
Mike M.
BNI/ECTA
Dynoroom
#1
A couple of things to try and help as this question does seem to come up often.
1) The rule book states on page 19 under 2.F In excess of 200 MPH: Special tires for racing as designated by the manufacturer.
This means the maker has said in writing the tire is a racing tire. (see below)
2) There are two types of "frontrunner" tires made by Goodyear that are commonly used in LSR. one is the drag tire the other is the LSR tire made from the drag molds. The LSR tire has a speed & load rating from Goodyear (go to their website), the drag tire does not. However all of the tires are marked "FOR RACING PURPOSES ONLY" making them legal for LSR racing.
Hope this answers your question.
LSR Mike
Thank you for the answer, I thought that was the sentence that qualified them.
Thanks!
Mike M.
BNI/ECTA
1212FBGS
for the speed and weight of your vehicle i think you would be safe with the front runners up to 200mph
kent
Cajun Kid
For a 4000  car at say 220mph, I am not certain the Drag Frontrunners would be a good choice ??
Anyone have experience with them at this weight or higher and speeds in the 200 to 225 range ?
I had planned on buying the Good Year Land Speeds as they have a higher weight and speed rating .
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
jl222
#6
Quote from: Cajun Kid on October 15, 2010, 05:00:29 PM
Charles
 We used the non LSR goodyears for many years on the 222 camaro with several runs in the high 260 mph one at 275
in 1991 and 288 mph with a 279 exit speed in 1994. 222 car weighs aprox 4800 lbs with 35% on front.
We never had any problems.
 We went to the LSR tires  in 08 they cracked, bought new ones this year, we had no cracking problem with the non LSR tires.
LSR Mike
I've got a 2500Lb curb weight Mini Pickup, Weight isn't the problem, I'm actually thinking I need some ballast in the back end. My real goal is to lower the front end with the smaller diameter of the Frontrunner.
Mike M.
BNI/ECTA
Cajun Kid
Mike, what size fronts ?  24 ?
Charles
OHIO
B/CGALT, C/CGALT
LSR Mike
22's, another 2" drop in the front over the 26" installed.
Mike M.
BNI/ECTA
desotoman
Mike,
If you want 22's go with M&H like the roadster has. Much better tire than Goodyears drag frontrunners for a front tire.  IMO.
http://www.mandhtires.com/store.php?crn=74&rn=288&action=show_detail
Model T Steve
22" M & H's on the front- What do you run on the back?
jl222
Quote from: desotoman on October 17, 2010, 10:29:12 AM
Mike,
  Thats the one tire that we had that a small chunk came out. Been 20 yrs ago but it seems they rated them at 400 mph
and I was suprised how thick the rubber was.
desotoman
Quote from: Model T Steve on October 17, 2010, 08:23:10 PM
In the past I have run 28 inch drag race goodyear frontrunners, but when I bring the car back out I am thinking about changing tire size and may end up with dunlaps or blockleys. Depends on what size motor I end up running, and how much weight I put in the car.
PS. From what I remember when Kaplan and Carr set the first record over 300 at El Mirage a set of shaved M&H's were on the front of their car.
Avanti Kid
I've been using Goodyear front runners (non-LSR) for years with no  problems, my car weighs 4,200lbs (50% front & 50% rear) using 23" in front and 28.1" in rear at a speed of 216mph at Bonneville at World of Speed.  Dave
Original owner of 1963 Avanti; Age 84
2006 Bonneville 200 MPH Club Member
Canyon Country, CA
215.6 mph 289 CI Studebaker engine
