LSR bike for sale
Started by firemanjim, October 19, 2010, 02:02:29 PM
firemanjim
Hate to do it but this divorce stuff is killing me.No expense was spared building this.
Much modified 1995 Buell S-2, easily 35,000 invested not counting my man hours. 100" S&S Superstock cased motor,built by Rev-Perf to take the targeted 350 HP.Base bolt Hyperformance cylinders,R&R billet heads, HP billet throttle body,custom built Garret ball bearing turbo,Pro-flow oil pump,Baker 6 speed, Bandit Clutch,belt drive primary. Engine alone cost me 17,000,and added stuff to that. Too much to list but build sheet available.Spares.
Water to air Bell intercooler,all stainless lines.Jet Hot coated exhaust, custom,oil,gas,and water tank,
Full set of RR-1000 Buell bodywork.Motec ECU and all new sensors.(cost 5000.00 alone.)
Extended swingarm,frame steering neck had six degrees added,extra brace welded in like late tuber.Ceramic wheel bearing,steering damper,full chain guard Much much more.At least 90% done,was waiting on wiring harness to come back to start it. 25,000 or offer. Consideration given to someone who will finish.
Or part out for right money. 707 548-7906
tekebird
is this the bike you took to Aus.  used to have orange Airtech body?
firemanjim
Quote from: tekebird on October 22, 2010, 04:48:55 PM
It is the basis for it,complete redo on engine/trans,bodywork,etc
