El Mirage help
Started by BurtonBrown, October 22, 2010, 01:04:36 AM
BurtonBrown
I am looking for some help to run for a record at El Mirage.
We currently have the record in F/GT at ECTA and Bonneville.
The icing on the cake would be to have it at El Mirage at the same time.
I am a SCTA/BNI member already.
I am looking to see if someone can help get me into a club for the upcoming event in November weather permitting.
Realistically all I am really looking to do at this event is to get the rookie aspect done so next year I could make a stab at the record.
If anyone could help get me a pass in a car to satisfy the rookie deal that would be great. I am 2500 miles away and it would be difficult to pull all that way for the rookie deal.
Please give me a call if you can help!
Thanks
Burton Brown 920-585-0776
"Live every day like its your last....some day it will be"
John Noonan
Burton,
Getting you in to a club is the easy part, with the new Rookie orientation rules that are in place I am not sure if a rookie can set a record at their first El Mo event..get a hold of Nathan Stewart nathan_d_stewart AT yahoo.com and see what he says...
Good luck with your goal.   :cheers:
desotoman
Quote from: BurtonBrown on October 22, 2010, 01:04:36 AM
Thanks
I am confused with your post. If you are an SCTA member you are already a  member of one of the SCTA clubs unless you are an Associate SCTA member. If you are a BNI member that in itself does not mean you are automatically an SCTA member.
With that said, are you a SCTA member who is out of state and would like to hitch a ride with someone who already runs at El Mirage? So you can get your licensing out of the way for next year?
Please clarify.
BurtonBrown
Yes I am an SCTA member but I understand from reading the El Mirage rules you must also be a member of another club.
I am looking to join this other club, help out with some duties as I understand and make a rookie pass. Ideally it would be in a car that all it has to do is satisfy the rookie portion. I understand the record part of not being able to set a record as a rookie.
I am really trying to set it up for next year where I will try to bump our record up at bonneville and hopefully set one at El Mirage in the same trip. It is a 2500 mile drive for me to El Mirage and it is difficult to justify hauling a car 5000 miles to make 1 pass for the rookie part.
Thanks
Burton
jdincau
You must be a member of an SCTA club in order to be an SCTA member
BurtonBrown
Ok,
Then that is where the confusion comes from on my part. Sorry.
I thought when you have a membership in order to run at Bonneville and have licenses there, it was an SCTA membership. It must only be BNI. I am probably not the first to confuse this. SCTA and El Mirage events are run by SCTA (except world of speed) correct?
So I guess I need to read more. Anyway I will do that but still looking to see if it is possible to do whatever it takes to run for a record at El Mirage next year. I would like to get the rookie status out of the way at the November event if possible.
Burton
bvillercr
You will be very lucky if someone let's you buckle up in there car.  First, most racers don't get many chances to get good passes at Elmo.  Second if they have never met you how can they trust you.  Third, it is supposed to rain again next week there; so there may not be enough time to dry up.  The only advantage you may have is that it is a two day meet and the run would be a low speed.  Good luck on finding a ride. :cheers:
BurtonBrown
I do understand. Can you run a street car as they do at the world of speed with a helmet/fire extinguisher for thr rookie run?
John Noonan
Quote from: BurtonBrown on October 23, 2010, 03:18:03 AM
Thanks
Burton
Burton,
You cannot run a street car unless it meets all the safety rules for the class it fits in to however your rookie run can also be a motorcycle if you have one and are willing to make a few small changes to make it legal and safe..
John Noonan
Burton,
The rookie sticker may stay on your helmet all weekend and you will need to license up as well...it will not be a one run and done affair..
bvillercr
What is the record in the class you intend to run?  If it's under 175 then it may be attainable with less rookie runs.
BurtonBrown
OK,
What do you need to change on a mtorcycle?
BurtonBrown
The current F/GT record is 158
Burton, www.scta-bni.org  log on and click on El Mirage tab. Then open the operating procedures
It's several pages long with all of the requirements for the running there,. BNI has different requirements for running on the salt. These are in the rule book. The new rule book won't be out until early 2011. The revised El Mirage operating procedures should be out before the first meet and the updates/changes will be posted on the web site as well.
Everyone wishes you well but a lot of things are different between the dry lake and at Bonneville.
To join a club each one has heir own bylaws. Not all allow out of state members because of duties the clubs pull at the events. Some clubs require that you attend up to three meetings before they vote on a new member.
BurtonBrown
Thanks Glen,
I do have the procedures open and have been reading them. It seems to be more involved than either of the other two I have been at. (ECTA and Bonneville)
I have learned over the last 10+years that land speed racing is quite different than the late model stock cars I have been running the past 20 years or so.
Just doing it for fun, but now we have 5 records between ECTA and Bonneville and thought it might be neat to have the record (or attempt to) at El Mirage.
Anyway it doesn't seem like the stars are aligning yet, even mother nature is not being kind to the lake bed I hear.
I am pretty persistant and don't give up to easily though. So I will keep reading and seeing if I can fit in somewhere.
Thanks
Burton
