The Maxton Monster
Started by Fheckro, October 30, 2010, 11:33:53 AM
Fheckro
Hi all,
I am looking forward to really getting into this project. So far it has been sporadic. A little here and there when ever I had time (which is a premium commodity around here).
I plan to start with safety equip.
       Roll cage
       Fire suppression
       Seat / Harness
       Numerous other items to get into proper configuration
I will run the car through tech and see how it handles at whatever speed it will go (110 or 120) with the current old power plant and suspension. have l little fun.
Phase two - Build the motor and transmission.
9479 Monza C/CGC
Current record Holder @ 180.000
Fheckro
I got the car from my son after he wrecked it (not his fault). I decided to build a hotrod for the street ( I had no knowledge of Maxton or what went on there yet). I converted it to a V8 and cleaned up the body.
9479 Monza C/CGC
Fheckro
The first task was to beef up the inadequate sub frame to carry the big engine. To do this I cut a cross member from a mid 70s "B" body Chevy and grafted it into the Monza.
9479 Monza C/CGC
Fheckro
I also relocated the steering box and linkage about 6 inches forward. Doing this eliminates the need for  a special oil pan and allows a wider selection of engines to be used.
9479 Monza C/CGC
Fheckro
I took a full size B body radiator and built a support to carry it. the radiator lays back at about 15 - 20 degrees.
9479 Monza C/CGC
Fheckro
The drive train consists of a turbo 350 and a Ford 9in rear end.  I will swap the automatic for a standard eventually (in phase 2)
9479 Monza C/CGC
Fheckro
As soon as i get room in the shop (soon i hope cause the wife is kicking the Monza out of the regular garage for the winter) I will start dismantling the interior to add the roll cage and stuff.  Right now I'm modifying/restoring a 69 mach 1 (another project that I got committed to before I experienced Maxton) but my head is at Maxton.
More pictures as i go, but I usually don't have time to even look on the computer much less post (today I hurt my back and can't do anything except sit here, and even that hurts!).
Fred
9479 Monza C/CGC
That is a nice clean looking car.  It is not overdone, stylewise.  Just right.
Fheckro
Thanks. It did turn out nice. I almost hate to cut it up for Maxton...almost. :evil:
9479 Monza C/CGC
Fheckro
I'm getting ready to buy the cage material.
Has anyone used Competition Engineering stuff? http://www.go-fast-parts.com/5709255.html
9479 Monza C/CGC
bearingburner
Check with the rule book to see if is heavy enough for ECTA rules.
Cajun Kid
Quote from: Fheckro on December 22, 2010, 04:57:05 AM
[/quote
This cage set up is legal  using the  1 3/4  .134 tubing,,, Dont order the 1 5/8.. ask them if it is DOM or EW tubing
I prefer DOM... but at .134 thickness and a good TIG welder all will be fine with this kit.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
With a .134 wall on either DOM or ERW tubing mig will work really well. You've seen how all the NASCAR cars can fly and hold up and that's the method of construction they use.
BALS aSALT
i second the cajun kid, DOM and tig. i don't care what nascar does. my cage ...........13/4 X.156 DOM, tig welded. :-D :-D :-D
it is better to live one day as a lion, than it is to live one thousand days as a lamb. or maybe it is better to burn out than fade away.
38flattie
#14
Quote from: Cajun Kid on December 22, 2010, 05:47:08 PM
[/quote
Charles
Wish I had seen this sooner! Why not the 1-5/8?
edit: Nevermind! I just read the rules for the other classes, instead of just the one I'm building for.
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
