dry sump tank
Started by BALS aSALT, October 30, 2010, 09:40:17 PM
BALS aSALT
what are your thoughts on the dry sump tank inside the car next to or behind the driver in a sealed compartment? legal or unsafe or what?
it is better to live one day as a lion, than it is to live one thousand days as a lamb. or maybe it is better to burn out than fade away.
I think it just has to be secured well---lots of folks put them inside.
maguromic
Closer to the pump the better.  Tony
If you're going to do it run a line from the vent to outside the driver's compartment. I really don't like the idea because it's a relatively heavy item that if it comes loose can be lethal as well as the fact that a hot oil bath doesn't do a lot for the complexion. :evil:
While I say that I have done it on short track oval cars where the crashes don't tend to be so violent and the tank is well protected being inside the car.
panic
#4
BALS aSALT
all very good points. think i might see about making room in the engine compartment. if too tight then i'll think of another spot.
Gwillard
Hot oil is extremely flammable. Best to keep it out of the drivers compartment if possible.
Will weld for beer :cheers:
BALS aSALT
Quote from: Gwillard on October 31, 2010, 08:27:59 AM
i agree. i was thinking if i had to put it inside the car, it would be in passenger footwell in an enclosed compartment. like nascar does only they do it  behind driver seat.
panic
The better tank shape is a tall, narrow cylinder - tough to have enough volume, and still mount it there.
BALS aSALT
Quote from: panic on October 31, 2010, 04:28:22 PM
can you please tell me why a tall tank is better? i was planning on at least a 4gal. but prefer a 5 gal., that WOULD be very difficult in pass. footwell.
jdincau
After years of messing with a tank I built for our modified roadster that was theoretically correct, I broke down and bought a 4 1/2 gallon Peterson tank on eBay for a song. The difference a professionally designed and built tank made was night and day as far as de aerating the oil. Tall, multiple baffles, swirl inlets and a stand pipe up the middle make it work. Be sure to follow the makers advice about vent tube diameter and routing.
dw230
Jim,
That sounds like a Patterson tank, I am not familiar with Peterson tanks. Are they another manufacturer?
jdincau
#12
dw230
BALS aSALT
Quote from: jdincau on October 31, 2010, 04:44:43 PM
10:4
