Datsun Modified Sports Build
Started by manifest, December 01, 2010, 08:20:42 AM
manifest
We have been building on this car for 6 years now.  What once was going to be a mild street car turned into a super low road race styled approach then about a year ago we decided a land speed car would be its best use.  The body and front suspension are going to stay stock for the most part.  I moved the top strut mounts up and built new control arms that are adjustable. Tubular cross member with plenty of room for the Mopar wedge powerplant we intend to run.  A jerico dr4 is in the works and a 9in. housing is held in place with a triangulated fourlink.  Dual caliper rear disc will keep it from rolling along with dual chutes I believe.  Firewall back is all 1-5/8" tube chassis.  Plan to build a more aero front end with completely disguising the cars original shape.  Slow going now because of customer cars but hope to jump back into it after the first of the year.
Zach
Manifest of Speed
maguromic
manifest
Tryin to.  Think they are to big.
manifest
OK so I can get the pictures to upload.  Check out my blog if the pictures.  It's work safe.
www.manifestofspeed.blogspot.com
Zach
I gather you're talking about the Datsun. :? :? :?
manifest
NathanStewart
Cool.  I LOVE the Ghia.  One of my favorite cars at Speed Week.
What's the time line on the Datsun?  What?  Dat-soon?   :-D
El Mirage 200 MPH Club Member
lvsalt
Hi Manifest looks like you are off to a nice start. What speeds are you wanting to go ? :cheers:
Gary Cole     DCWATERJET Z
manifest
We hope to have the Datsun ready by Aug-Sept of 2011 if everything goes well.  Dad's trying to sell his motorcycle to help fund the project a little better right now.  The hardest part is done I hope.  We are going to run the motor out of my NHRA super stock dodge dart to begin with I think.  The stock stroke .030over bore 383 motivates a 3200# dart into the 130-132mph range in the 1/4 with a jerico on 31in tall M/Ts with stock size valves going thru the traps at 7800rmp.  We think with adding a dry sump and a carb bigger than the 625cfm carter avs we are restricted to in the dart we can get into the 190-200mph range at bonneville and 160-170mph at maxton.  We have talked of de-stroking a 440 to be in the upper limits of B/GMS.  I have talked with some outlaw drag racing buddies about a centrifugal blower and we may end up running a rons fuel injection set up also... all of that is still just dreams.
Zach
debgeo
Dreams are a good place to start.  :-) :-) :-) :-)
George---Sidecar in progress
lvsalt
 in the 200mph range with the Z allow plenty of space to add weight. Ive been around a few times  :-o
"I've been around a few times."
Ya mean like around and around?
manifest
Yea we found out how important weight and spring pressure is at SW with our ghia this year (thru the 2 backwards).  In the Datsun the 2x3 front frame rails and some of the other larger dia tubing will have fill bungs in them so we can add weight inside of them and also have mounting points for weight placed throughout the car naturally.
Zach
manifest
So I just read the updated rules SCTA has annouced.  I want to make sure I have read them correct, so please chime in if I have interrperated this wrong. "A generic requirement for this category is the car shall have been originally produced with seating for 4 or more people, i.e. adults or children. If the car was produced and sold with 2 seats on some models and 4 seats (including jump seats) on other models, the car will be classified as a Coupe and Sedan. Examples include Honda CRX, Ford Mustang GT 350's, Porsche, Nissan Z 2+2, etc."  ....  So now we can run our 280Z in Modified Sports, or Coupe class?  Ours is not a 2+2 but as it were a regular Zcar had to run in MS and a 2+2 only quailified for Coupe or Sedan, correct?  Now we are aloud to cross over if our car was produced in two forms........
Zach
lvsalt
