Lateral Support Pics
Started by Cajun Kid, December 04, 2010, 01:18:26 PM
Cajun Kid
I know the 2011 Lateral Support rule has a bunch of us wondering what to do and how in the heck we can get in and out of our cars if we complied with the rule "as written"  Here are some pics that may help.
1. Yes  lateral supports that meet the rule wording are available, these pics show the right side support on one of my seats, you can see that the support does extend past the chin bar of the helmet. However,  If I used this length support on the drivers side, I would not be able to get in or out.
The Head side supports on my other containment seat does Not go 100% past the chin bar of helmet, but it sure seems like  more than enough side length to keep the head supported. I could not imagine an inspector questioning this support at all...
I would hope this is enough to meet the rule as any more length and I could not get in or out of the car.
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Cajun Kid
#1
Here are a few more pics that show how the seat design and depth has Hip, Rib, Shoulder and Head Supports built in and coordinates with the proper belt and HNR installation.
Keep in mind it is sure hard to take these pics and hold or keep helmet where my head would go all by myself, so hope they are not to blurry for you to see the details.
less than 1" side to side clearance, so well under the 2" per side rule wording
Any questions or if anyone needs a differant pic or a measurement just let me know.
Charles
OHIO
B/CGALT, C/CGALT
jl222
#2
Quote from: Cajun Kid on December 04, 2010, 01:18:26 PM
Charles
 Thanks for the fotos Charles, If those supports are required in cars with shorter doors a lot of racers will have trouble.
 Thanks to Dan, SCTA is taking a closer look. It's noticable that the foward part of support drops below vison.
  Also if 2 inches is required for the full length would your seat pass?
debgeo
Charles I really appreciate your input on this forum. Great pictures and hopefully will help define what is needed.
George :cheers: :cheers: :cheers:
George---Sidecar in progress
Bob Drury
  My biggest problem is that if I lean forward, my triple chins hit my front porch and neither want to budge.   Next year I am pushing for a spandex fire suit rule........................ 8-)
Bob Drury
Cajun Kid
JL222,
YES, My seat would pass the the 2" side to side rule the entire length of the side supports,,, it is hard to see in those pics but when the helmet is centered where It would be when I am belted in.... there is just a smidge over 1'' per side clearance,, it is tight in there... I do have 3 lengths of supports available,,, short, med and long.
The pic with my hand holding the left , driver side support and helmet (the one in the Stude)  is the medium length side supports, which go "almost" to the forward edge of the chin bar.. very very close to 100%.... the long length is shown in the Vicky on the right side... No way the long length would work on my cars for the left (entry side of the seat).. I would bet ANY car with a support long enough to go to past the chin bar of helmet would make it just about impossible to get in and out of for most all drivers.
As you can see my cars all have side supports and I used them and HNR's  well before any rules told me to.
I agree with the need to use them.
 What I think is the wording of the rule needs to be changed as well as the spec's... there is no need for the side support to go to the end or past the chin bar.  at least 1/2 way to 66 % is enough, they could use a percentage 60% ie  for the distance spec, or simply say side supports must extend at least to the mid point from the chin bar to the eye port opening or the face shield hinge point  etc...and supply a drawing in the book.
Charles
OHIO
B/CGALT, C/CGALT
jl222
Quote from: Cajun Kid on December 04, 2010, 05:26:37 PM
JL222,
Charles
  Yea Charles, I agree with those possible distances, and hopefully SCTA will also.
                    JL222 :cheers:
Cajun Kid
The distance could be taken at the eyeport opening or the shield hinge point,  see furtherest left red arrow, another at the chin bar (far right red arrow)  then take 50% of that is the middles red arrow and then say the side supports must at least go to that point,,, (white arrow)
The arrows on my pics are not perfect,,, I am no cimputer whiz,, just thinking a picture may be better than all these words,
So if the side support stopped at the P   in ISP,,, that should be enough and allow us room to get in and out,
Charles
OHIO
B/CGALT, C/CGALT
CK, you did not specifically say that that was the 2010 Snell but it must be, if you took more than 2" out of the width---thanks for the very revelant pictures.
Cajun Kid
#9
Sparky,,, the Lid in the pic is my old Snell 90 Helmet.   The 2.09 I spoke of was from the Side Support FRAME... not the Hard Cell Foam or velour/nomex covers.  I thought the 2" excluded any pad or cover,, so all is well now, I am about 1.125 " per side in the pics,,, When my Snell 2010 comes in, I am sure it is a bigger helmet than the SA1990 in the pics. I could have used my current SA2005 but it was packed away in the other shop and it was snowing when I took the time to make these pics. (cold and lazy today)
If the SCTA revokes the rule or modifies it I am STILL going to use as long a side support as I have and can that will allow me in and out of the car.  (mine works good for support and ingress / egress as is now is plenty long now.
Charles
OHIO
B/CGALT, C/CGALT
hitz
CK,
Is that the angle that the helmet is at when you are wearing it and in the seat? It looks like you would be looking at the ceiling. If doesn't go at that angle and the forward part of the helmet will be rotated down a little all of your concerns should go away (and hopefully the scrutineers too).
The group that put the rule book out do a good job on a really difficult task. There are gray areas but a little common sense will take care of most of them.
Harvey
55chevr
Keep drinking the Kool Aid ...
Cajun Kid
#12
Quote from: hitz on December 04, 2010, 10:21:11 PM
CK,
Harvey
Harvey, it was hard to hold the Helmet in place by myself and take the pics,,, you are correct when the Helmet is up a bit and angled chin down a bit more , where it would be when on my head,,, then YES in my current set up using the MID LENGTH  side supports I am within the new rules... I knew I was LEGAL for the New Rules,,,,
The reason for my posts and pics was not to plead my case, it was to
1. Help Other car guys and 2. To HELP the RULES makers "SEE" what we face.
Charles
OHIO
B/CGALT, C/CGALT
krusty
Well, Charles, what if you end up with the driver's side of the car down? Need to have an "exitable" length on the left side also. I, too, think that this rule change  has not been thought all the way through. Hopefully, DW is watching this thread, too, and will help to carry competitor input to the board.    vic
Cajun Kid
Vic,
With the wide open unobstructed (no walls or fences to lean up against) courses we race on, I do not think even after a crash the car could end up stationary and balanced on the drivers side, or the passenger side.  (short of  a Joey Chitwood stunt show, I did not feel this situation would occur)..
The most likely  situation would be a spin resulting in lift causing the car to flip, roll or tumble... coming to rest on the roof or the wheels. Not likely on it's side.  We did design the cage with this possibility in mind,, so that it would not lay flat on its side,, also with a middle roof bar that is raised above the  A to B  bars. promoting a "Roll" back to the wheels.
But then again this is just all theory,, every crash situation is differant.
So YES  you are correct the side supports should not limit exit from either side. On the Stude my side helmet supports are the same length on both sides.  They are the length that does meet the new rule wording and also are as long as they can be allowing me to get in and out quickly.
As to passenger side exit ??  Look in a bunch of Race Cars,,,, LSR, Drag, Various Circle Track cars, Road Race, SCTA, Mud race etc,,,, I think what you will find is most all of them have much more "stuff" on that side making exit or extraction much more difficult than from  the drivers side. But I know you knew this already.
Charles
OHIO
B/CGALT, C/CGALT
