370c.i. BBC rotating assy.
Started by racergeo, February 06, 2011, 10:15:03 PM
racergeo
  I have a new Bryant billet crank with a 3.1 stroke to suit a BBC with a 2 piece rear seal. It is a light weight piece that is full counter weighted knife edged and a work of art. I have a set of Manley nitrous alum. rods that are impinged and are 40% stronger then reg. rods, they are 6.6in. long. Also a set of SRP pistons#139533.theyhave 4.350 bore and a 1.645 pin ht. Dome is 46cc. It would make about 11.5 comp. ratio if you did some serious work on the heads and make a good nitrous motor with a lot of swept volume ( see David Vizard). Or with a little mill on the domes and a 116 cc combustion chamber a good turbo engine. This idea cam from the Dirty OLd Men lakester that used a C BBC engine to run over 360mph. Joe Law's combo used a 348 crank (3.25) stroke and a smaller bore.With the right turbo set up this should be capable of 1500hp. Also have a block if you are close by. Contact me through Land Racing. Leave a phone # and I'll call.  George
