street roadster_----gas roadster
Started by judgekiller, February 22, 2011, 06:42:47 PM
judgekiller
If I had a legal street roadster could I run as a gas roaster  If not what would I have to change  I realize  I would be at a competitive disadvantage
Get a rule book, read the rule book, again and again, is it an SCTA legal street roadster or a street legal street roadster, lots of differences...
Stan... your turn.....  :-D
Nortonist 592
I think Stan is busy filling out the protest forms.
4-barrel Mike
NathanStewart
Remove the rear fenders and headlights from your hypothetical street roadster to run in roadster.
El Mirage 200 MPH Club Member
judgekiller
jdincau
Quote from: NathanStewart on February 22, 2011, 09:37:42 PM
Providing it is not a pre 1928 roadster
jww36
The big difference is engine set back. 25% for gas/fuel roadster and only 15% for street roadster.
An even bigger difference is the driver set-back advantage of the Altered Roadsters over the Street Roadsters.  In Street Roadster, the driver must not sit back out of the stock passenger compartment.  In Gas and Fuel Roadsters, the driver can be farther rearward, allowing the driver to get down out of the air.
The Dodge Boys with their V4F car set Street, Gas and Fuel Roadster records at one meet a couple of years ago.  You can search for them here.
Stan
Ron Gibson
In 1990, Tony Piner set a record with his A Street Roadster. The record was faster than the A Gas Roadster record.
He took off the headlights and fenders and re-entered as a Gas Roadster, then set a record in A Gas Roadster also.
Don't know if others may have done the same.
Ron
mkilger
the word on the salt is that some one is building a street roadster to run 300 :roll:  good luck
That's getting harder to do.  Some say you're only competing against yourself in land racing.  While that may be essentially true, running in the B, C and D roadster (Street, Gas, Fuel and Modified) classes is running against a lot of hard-fought records with more competitors than most of the other categories.
Stan
jimmy six
You can run a Street roadster in Modified roadster if you like. Some have done it and set records to establish something other than "open". Actually it inspires competition and I have no problem with it. Many "fuel" records have been set with gasoline as well.
As I read it and have read it, there are no requirments to run up in the roadster classes like in the coupe classes..All the rules as I read them say "you may" not "need"...This applies to belly pans. extended noses, wings. etc... You get the picture? ...Good Luck
JamesJ
Quote from: mkilger on February 23, 2011, 08:30:41 AM
I agree, Good Luck
