Lateral helmet supports
Started by 836dstr, May 07, 2011, 12:13:03 PM
836dstr
OK, thinking outside the box or inside the cage:
Enclosed here is a picture on the current lateral supports inside the shoulder hoop of my roll cage. Per the new rule stating the "support" must extend forward to the front of the helmet means that I need to add 4 inches to the current structure.
I am still concerned with exit and enter with the new "Head & Neck" restraints.
Does the support need to be fixed in place? By this I mean could the support be hinged for upward travel and secured in a down and locked position by using additional "seat belt straps" connected to the crotch strap quick disconect that would be routed over the legs off to the side through a bracket or roller in a vertical plane to the support.
The intent would be to have the supports secured in place in a down or horizontal position when the driver is belted in, but would allow the supports to pivot up as the belts are released.
Dan, J.D., any ideas?
dw230
I am not the guy making the decision, 2011 rulebook , page 26, fig. 3 shows that the front bar has to be a minimum of 3" in front of the helmet. Do your cage tubes meet this spec?
Captthundarr
Can you prop a helmet in there for ref?
jdincau
Tom,
     Here is what I did to our cage last year. Note that it is tapered at the front to keep the helmet from catching on it when rebounding from an impact. Joe Hansen at DJ suggested this. Tony thinks egress with his DJ head restraint will be no problem.
jdincau
another view
jdincau
and another
Rcktscientist
Tom,
I see on your present configuration the laterals are moved in close to the helmet. That is what we thought was needed in the old days.  In the unlikely event of a crash ideally you want your head supported (HANS or other device) and not hit anything. We know the belts stretch and you can get bounced around alot and will probably hit the sides, back and even top hoop. The protection in these areas should be of a material the cushions your head and springs back before the next hit. I have ISP laterals in my rail because NHRA requires SEMA Spec., but Rick White (Autopower) can fix you up with fitted laterals. I would recommend all around protection like he has on his Rail. You only have 1 head, so protect it the best you can.
jdincau
Tom,
     I forgot to add that I think getting out of the harness with the added encumbrance of a head restraint will be challenging enough. Adding additional latches/links for a movable lateral restraint will be overly complex.
Jim
836dstr
Thanks Jim,
I was originally planning on doing something similar to your setup.
After some more thought, having some setup using belts with the proper tension would probably make doing the lap and shoulder harness belts a real hassle.
Back to the drawing board.
