Franklin - a man before his time
Started by dw230, May 10, 2011, 08:36:23 AM
dw230
RichFox
I have noticed that when Top Fuel cars crash the drivers part of the car stays pretty intact and the rest leaves. As with Indy type cars and others. Burn up energy disassembling the car and remove hot, heavy, burning pieces from where the driver is. How does this differ?
Gwillard
Quote from: RichFox on May 10, 2011, 09:29:15 AM
It differs in several ways:
It is lighter than a steel tube structure which means it carries less energy to have to dissipate.
It is, except for the opening to get in/out, solid-sided. Greatly reduces the chance of cockpit intrusion by debris, the #1 cause of injury in race car accidents.
It deforms and rebounds to retain it's shape. Steel deforms and stays.
It is far better at keeping fire from the driver as well as debris in the event of an engine or driveline failure.
Will weld for beer :cheers:
maguromic
Quote from: Gwillard on May 10, 2011, 09:41:56 AM
This is why we are building a safety tub for the roadster, though no canopy. Tony
Dynoroom
I didn't know fuelers were around in Benjamen's day........
Oh wait, you meant...... never mind....... Then again, do you suppose Schumacher will need to pay him royalty's? Then he could rent a track and really fly......... so to speak   :-D
aircap
Even a blind pig finds an acorn once in awhile.....
"Act your age, not your shoe size". - Prince
#6
Deleted - after further consideration.
Dean Los Angeles
QuoteIt differs in several ways:
The picture clearly shows a steel tube roll cage.
I think the advantage is in fire and debris intrusion. The aero must be better also.
Oh, and no chance of drowning.
jimmy six
As I read it they say it's a "totally enclosed cockpit system" but it sure didn't look like it could be removed like they have in the boats.  They aren't showing how it is attached or if it's just a sealed cockpit area. The picture with Tony in it still shows tubing below his shoulder and what appears to be the outside skin.
If it can come out there will be many connections for whats both infront of the driver as well as whats behind..............Didn't Garlits has a sealed driver cockpit years ago or was the back open?
JD...Just looking at the photos
floydjer
redrock_2003
  This project should be interesting to watch. Unfortunately when you are trying to satisfy sponsors and win championships safety often gets a back seat to winning. I recall about 10 years ago several top fuel teams installed carbon fiber panels on the inside of the cockpit to improve safety. (This not only helped to prevent parts from entering the drivers compartment in the event of a crash it also eliminated the possibility of the drivers legs beating against the roll cage tubing. Therefore helping to reduce the possibility of a lower leg injury.) Unfortunately the panels added the dreaded WEIGHT to the car and the panels were removed within a couple of races. Another issue will be how the drivers pod will alter the flex of the chassis.
http://www.competitionplus.com/drag-racing/news/17599-dsr-capsule-s-biggest-obstacle-is-weight
Tman
floydjer
It`s o.k.....Maybe even advisable to agree w/ Dan...Just try not to agree with you know who. :cheers:
