Indy or straight?
Started by RICK, February 03, 2006, 10:57:36 AM
RICK
I was just going thru some pics in "BUILD DIARYS" and I saw a Vega with a front tube axle? Is that the prefered suspension or would a independent front be better?
And I think it had a PACCARD? motor? Why?
landracing
That pictures was Rich Fox's car. You ask why a Paccard.. Because he had one sitting around probably would be the answer...
Jon
JackD
It is the same "Burning Desire" that caused the first person to Climb Signal Hill. :wink:
RICK
Packard motor/top loader in a Vega racing car? In my heart, in the pit of my stomach, I know why. I just can't explain it to anybody I know. Don't get me wrong,,, I think the consept is way way cool. Almost better than sex. I just don't have the nuts to try it.
 Which brings us back to the original question, ,,Which works the best, independent or straight  axle and why?
       eye think my spell check, she is no workin
JackD
If you are building from scratch the straight axle offers less monkey motion unless you have to take it under the motor.
The various speeds and conditions seen by an LSR vehicle don't require near the suspension science that other series need but it does have to be strong.
A drag race set up on the front of a car that would run forever on the strip failed on the salt and put the driver on his head.
dwarner
Bill Ward's Opel has the axle welded to the frame as does many a Lakester and Streamliner. Works just fine for what we do.
JackD
Quote from: dwarnerBill Ward's Opel has the axle welded to the frame as does many a Lester and Stream liner. Works just fine for what we do.
Bill has a BBC in an Opel GT that runs 250 if you need test results. :wink:
RichFox
When I built the car a tube axle with early Ford type suspension was what I was used to and easiest to construct. I have run the car with different GMC 6 cylinder engines, a 460 Ford, 455 Pontiac, and a 392 Chrysler. When I was a kid I thought Packards were neat. I have never seen a Packard powered Vega. I have some Packard motors. What's the big deal. At least it's not a '32 Plymouth with a '57 Ford head. The car has a best run of 208 mph and many runs in the 180-208 range. Always straight and easy to drive.
Just to present a different perspective, last year and some other years provided some real difficulties for cars with no suspension.  They will come again and if the time to run is limited, you have paid up front and you want to run under varying conditions I would suggest some suspension even if it is very limited.
Keith showed last year that with some well thought out suspension you can set a high speed record on really bad salt when most of the other solid suspended cars are parked.
Just my thoughts,
russ jensen
8) I was told the salt was so smoth that I needn't worry about bump stear or any of that, didn't quite beleive @ time , must be salt isn't always smoth, I keep thinking about the yellow crosley that went airborne @ 300+, Tape said he lost wheel but it looked like he hit a small bump that resulted in [what a ride] can't beleive he survived it.
speed is expensive-how fast do you want to go?-to soon old & to late smart.
Dynoroom
Quote from: russ jensen8) I was told the salt was so smoth that I needn't worry about bump stear or any of that, didn't quite beleive @ time , must be salt isn't always smoth, I keep thinking about the yellow crosley that went airborne @ 300+, Tape said he lost wheel but it looked like he hit a small bump that resulted in [what a ride] can't beleive he survived it.
Russ, Earl did in fact have a right rear tire go down, this allowed the front to pitch up (looking as though it went over a bump) The tire was blistered badly and deflated. He had this problem (blistering) on a previous run but didn't put 2 & 2 tegether 'till after the crash.
russ jensen
:?: 2 pt ? why do tires blister, was he spinning them and getting them hot. doesn't seem like the run would last long enoudh to get hot ? I rember somebody telling me that [I think it was vesco streamliner which had a bunch f cords hanging from rim] [ some multy ply tires from micky's chalanger] was told he had 500mph power & 400 mph car and spun all 4 wheels the length of course,  I degress; or was it low air pressure. 2nd part, if I rember he was running some pretty wide tires on back , is this a problem with open wheeld cars running eagles??
JackD
If you consider how tires are assembled, you will understand how they come apart.
The strength is in the cord body.
The rubber keeps the pressure in to help hold the shape and the tread provides the
contact patch to allow the power to contact the drive surface.
The tread is bonded to the case and is the point of failure with a blister.
Grab up a truck tread along the highway and take a close look at it.
The results are the same.   Like a grinding wheel. if your object is going the same speed
as the grinding surface it produces very little heat.
Get them going at different speeds like tire spin and heat happens.
Lots of HP produces lots of heat right away when it is put through a very small area and failures occur.
russ jensen
:?: Do open wheel cars get enough cooling from the high speed air to avoid this problem????
JackD
A shrouded tire will build more heat with all things being equal.
Things are never equal and the tires see different conditions every run.
One driver might have repeated failures and another in the same machine might make them last a long time.
Power, conditions, and technique all contribute to the life of the tire just like the resultant speed.
