Spoiler flap
Started by Bob Drury, June 17, 2011, 12:35:02 PM
Bob Drury
  Here is my attempt to keep my ass on the salt............
Bob Drury
Dynoroom
Wow Bob, must have found some young kids to post pictures for you?   :-P
Nice job     :cheers:
Bob Drury
  Dyno, I tricked Mr. Hotnut's into visiting.................
Bob Drury
geh458
Well, that looks like it will dump most of the air pressure should you find yourself going backward, but, lets not test it ok?
Gifford Hawn
Vintage Sports Car Racer looking to convert.......
Jonny Hotnuts
While talking Bob through the photo resizing process I secretly snapped this shot of me giving thumbs up behind Bob.
LOL
jonny_hotnuts@hotmail.com
*Andres Segovia
Bob Drury
  Now if that doesn't look like your neighborhood preevert, I don't know what does..........  Bob
  Hey, I didn't realize I had a grey pony tail............   :cheers: :cheers:
Bob Drury
Cajun Kid
Bob, nice job,,,
What holds tension on the flap when going frontwards ?  Just air pressure ?  Why the two inner spill plates (verticle uprights) ?
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Bob Drury
#7
  Well Charles, being the mechanical genius that I am, I mounted the tether strap's (hard to see but thay anchor at the base of the two red spoiler support's).
 When I got done, I tried the flap and it wouldn't close because the tether hardware hung up on the opening surround.
 Being a well organized genius, I started looking for a fix and found it on my screen door.
 If you look real hard you will notice the tethers are held together by the screen door spring.
 Dodge, I gotta go close the screen door again......... the wind just caught it........ :-D :-D
                                       Sign me: the smartest guy Hotnut's has ever met.................
  The two inner spill plates are because Dan said I could have them and it isn't often that he offer's any leeway or freebies, so I said "hot damn" I gotta go for it. (translation: I don't have a clue, but hopefully they add to stability if the air stream catch's them).            Bob
Bob Drury
jimmy six
Not trying to be a smarta__ at all but if it were mine I would put an air vent (or vents) from over the real axle to the spot behind the back window about 2" wide and 30 to 36" long relieving the lifting from behind the rear window and take all that "junk" off the trunk. Neil Thompson went right at 300 MPH with nothing but an air vent and the tail lights removed from his 53 Studbaker 40 years ago. All that stuff is drag......................
Check out Bruce Giesler's Studie for the samething. They work and were mandatory for Studies over 175 at one time.
Good Luck......................JD
Cajun Kid
Quote from: jimmy six on June 19, 2011, 06:37:32 PM
I was told those air releif vents where for classic Coupe,,, not classic altered coupe...
But that did not make sense....not sure the wind tunnel would agree with the rear spolier being drag ....
OHIO
B/CGALT, C/CGALT
jimmy six
CK Talk that over to Dan.....
FIRST: MY BAD THEY ARE AIR "DUCTS"
For some reason I cannot find mention of them in the Classic, Modified Catagory, Altered or Gas Coupe Rule from page 63 thru 70.
But on the first paragraph of 4.CC it sounds a like they are prohibited for directing air and that where they must be getting the prohibition of them. IMO It says "within the car" but not "threw" the car.
Like I said they were mandatory for Studies years ago because all, I mean ALL, of the spun between 175 and 185. All this "Junk" was added because of other cars to hold them on the ground.
To bad if they are not allowed. Geisler's Hanky Panky and the Terry Hunt's old Guam Bomb are probably illegal now....Too Bad
Bob Drury
#11
  J.D., while I respect your opinion, I totaly disagree.
 First of all, we now run our car's lower with front air dams, resulting in less air under the car.
 Secondly the air at the base of the rear window is a low pressure area and any air exiting from behind the rear window is if anything, going to allow less downforce on the rear of the car as the air over the top flows downward's.
 Terry Hunt's vents were for the radiator mounted under them.
 I would suggest that the major problem with the Stude's of thirty to forty years ago were caused by most guy's putting ballast in the trunk, creating a pendulum, and the high attitude and center of gravity ( partially caused by the tall tires with stock rear suspension's/ala leaf spring's).
 I have never been able to find a picture of Neal Thompson's Studebaker.  Bruce Geisler said in the end it ran a Corvette front end.  Was the body unaltered (chopped or skirted) when it ran those speed's?
 Just curious.
 p.s. I have another trick up my sleeve at the rear of the car keeping the rear planted, it's legal,  it aint weight, and to anyone who has seen my car it is pretty obvious and it's not the spoiler............. but  spoilers do work.
        Bob
Bob Drury
Bob
re read your #2  if it is low it lifts---the duct was trying to kill the lift area sucking the rear wheels of the ground
jimmy six
Sparky "you got it." The area behind the rear window on a car that has a defining line causes lift. There is no question about it. I don't care how low it is. It's the air going over the top causing the the problem and the air coming thru the ducts that break it up. I guarantee I felt it in mt 1940 Chevrolet 20 years ago. At 149 for 3 miles nothing moved. At over 150 you could feel the car rear coming up, right in your seat. We went 153 and that was it. No More. If I would have put in an air duct I'm positive it would not have lifted. A 1940 Ford would probably not have the problem until a higher speed because of it's slopping roof line. If you ever drive a car with the "lift" you will know it.
I'm not saying to not use spoilers especially in a car with no defining line. The guys in the past figured it out and the same would work today....Good Luck
Bob Drury
  Sparky, I guess the question would be is the lift from that low pressure more than the high pressure created when the air over the top hits the spoiler?  Does that air cause a turbulence or keep the high pressure from dropping down before clearing the deck lid?
  It's a shame that after all these years (58) no one has had the resources to put one of these car's in a wind tunnel.
  When I  was reseaching for my car at Speedweek in 96,97 and 98, I talked to every Studebaker driver on the Salt.  This included Studebaker Joe, Beard and Glade, Turner and Whitley, Homer Hinchcliff, and my friend Bruce Geisler amongst others.  Most ran air duct's.
  I asked each about certain features such as straight axles and the air duct's exiting the trunk.
  The concensus I gleaned was that many thought straight axles were the only way to fly, but not one of them could offer anything for reasoning other than "that's the way we have always run it".
  Granted, the stock Stude front suspension might not be the best, but Geisler's car has run a stock one since the 60's.
  The same thing applies to when I asked about the air duct's.  Not one of them could tell me if they had any proof  of them working.  It was more of a "monkey see monkey do" thing.
  As I stated in my previous post, the Stude's that ran  in the seventies and eighties may have benifited more than today's versions in that we can run a spoiler, but once again we have no proof of the advantage of the ducts whereas the spoilers are a proven design on virtually all full bodied cars.                        Bob
Bob Drury
