1980 Monza Race Car
Started by Leadfoot, June 24, 2011, 11:24:11 AM
Leadfoot
This Monza is a complete rolling chassis. The car still holds record at Bonneville, just put your engine in it and go racing. Set up for small block chev.
Here are some of the componets;
Turbo 400 trans standard shift,converterless
Ford nine inch rear with spool 3.00 ratio 4 link with disc brakes
Goodyear Racing tires on all four corners. 27 inch rear 23 inch front
Centerline wheels with moon discs
MSD BTM ignition box with coil
Complete DJ fire system 2 bottles
Stroud Bonneville Parachute
25 gallon water tank with pump
5 gal fuel cell
Magnafuel Pro Star 350 electric pump
Can deliver to Speedweek.
7500.$$
nrhs sales
I'm ignorant to the car stuff so pardon the stupid question...  But what is the 25 gallon water tank for?  Only 5 gallons of fuel and 25 gallons of water?  I am baffled as to what you would do with that much water?
Leadfoot
. . . and weight (including tank).
nrhs sales
It's a matter of preference.  I prefer no pressure, no radiator.  Your preference may vary.
Stan
Bob Drury
  If the Monza is run in the altered class the grill openings can be covered, hence the water tank is a necessity.
Bob Drury
. . . and even better in the back.
AJR192
The car is the blue Monza number 475 owned by the Spencer family. The nose is blocked off. It is a good deal on a proven car. I hope it sells quick Gary. Good luck.
PackardV8
Is the roller turnkey?  Current log book and would pass tech?
jack vines
Leadfoot
Yes the car raced all three Bonneville events last year. It was setup for small block chev with twin turbos, current logbook. Please send me a email at   spence1933@hotmail.com   and I will send you some pics if interested. The car is Located in Northern Utah.
hotrod
Sorry to hear you are selling the car Gary.
Here are two shots of the car on the salt.
Larry
Bob Drury
  Gary, I would say your father was one hell of a driver to handle a twin turbo motor with that short wheelbase!!!!
  I hope to see you at Speedweek.................. Bob
Bob Drury
RichFox
Jack...Your killing me. This weekend special on Vega/Altered coups. Call for details.  RF
Leadfoot
Bob, with that little small block it was a bear when the turbo's came on. But the car went nice and straight at speed ran a 212 exit .
